ownCloud Virtual File System - Discussion
This is a great feature. I really love the idea of having the whole structure in the finder.
I installed 2.5.0 client on Mac, enabled experimental features and re-added my connection checking the VPS option. However, the ownCloud folder just stays completely empty and I don’t see any sync activity going on. The top bar icon shows the check mark. What do I do wrong? Really want to test this feature.
I’m on MacOS Mojave.
Can you try again with this package?
https://download.owncloud.com/desktop/stable/ownCloud-2.5.1.10818.pkg
Virtual File System only worked when I had default owncloud share. All my files are on external storage (a WC mycloud NAS, OWC runs on a pi3b+). When i ask to download the files using the client right click action nothing happens.
I’m using 2.5.4 (build 11456) on mojave 10.14.4 (18E226).
When I’m using full file sync it does work
@Tiago_Santos could you check with the 2.6.0-alpha1?
In case the problem isn’t fixed, please open a new issue and provide the necessary information:
GitHub · Where software is built
It is better, but still it doesn’t gives the usage for real life context. If you’re patient enought to open the browser and download the file you need it works, else you must do real file sync and it doesn’t work so awesome…
Other issue (good and bad) when I dele files it doesn’t propagate to any external storage sync I’ve.
2.6.0 beta1 has been released which contains many improvements on the VFS side, both for Windows and macOS/Linux platforms.
Virtual file feature taking hours to make first sync, in my case it took about 3 hours to sync 46GB of data.
My understanding is, currently sync client checking all files one-by-one on server and generating a database file on local computer and making empty file for every file on server.
My suggestion is to generate the user database file on server and send it across o sync client and then create the local empty files, this way virtual file sync will be instant.
2nd option
Initially generate the structure of root directory make is available to for user to see and keep generating the structure of sub-directories as the user is navigating the directory tree this way user will feel that all the data is already there and, in the background client can keep syncing the full file structure.
@munim Thank you very much for your valuable feedback. What exact version of the client did you try? What is the exact version of your operating system? We’ll release a RC1 the next few days that should behave much better.
Thank you for noticing and responding my post.
I tried 2.5.4 and 2.6.0beta1 on windows 10 x64 built 1903 and both have similar behaviour.
@munim What steps did you perform? New initial sync with no files local and a big remote account? Or did you added the files to an existing sync folder connection? What number of files did you test?
Please try 2.6.0 rc1 :slight_smile: it might behave better, especially on Windows 10.
Download links are at 2.6.0 · Issue #7063 · owncloud/client · GitHub
Yes it was initial sync around 44k files and total data size was 46GB.
Thank you i will try.
