we have an owncloud setup and currently have users syncing to it which works great, one thing we would like to know is rather than setting their email notification to be set to “weekly” and for them to be sent out a week after enabling, is there a way to specify that all updates, regardless of when it was applied will be sent out on say sunday evening as an example/?
if this is the personal section of your ownCloud server installation then i think the “Desktop Client” category is not the correct one. Maybe a moderator can move this to the right one.
If there is no such selection of the day then i think its just not possible to configure this.
i don’t think so. AFAIK the E-Mail notifications are coming from the server and @dunn2010 is probably referring to the “Weekly” in the personal settings here:
This is correct Tom, was wondering if there was any settings server side that can be modified to say weekly emails are sent out on sundays / Mondays etc?
i don’t think that there is such a setting available. But maybe i don’t know all available settings so you could check the config.sample.php within your /config/ folder so see all available ones.
