OwnCloud Will not Write into Config Directory
  1. Create a new database
  2. Download the zip files and unpack
  3. Run the web-installer
Owncloud should go to an interface where it asks you to input details such as use the sqlite Database or a Maria database, the name of the database etc. and then complete the instalation.
Installation stops with the following message:
Can’t write into config directory!
This can usually be fixed by giving the webserver write access to the config directory.
Ubuntu 18.04
50GB Memory
2GB Working Memory.
Maria 10.4.16
PHP 7.4.12
10.5
Fresh
IP file
AH01071: Got error 'PHP message: {"reqId":"c39b8ef0-f0d1-4618-907e-46896ea1e7ac","level":3,"time":"2020-11-10T09:48:13+00:00","remoteAddr":"147.86.223.240","user":"--","app":"PHP","method":"GET","url":"\\/owncloud\\/status.php","message":"touch(): Utime failed: Permission denied at \\/var\\/www\\/vhosts\\/e4p.ch\\/httpdocs\\/owncloud\\/lib\\/private\\/Config.php#280"}PHP message: {"reqId":"c39b8ef0-f0d1-4618-907e-46896ea1e7ac","level":3,"time":"2020-11-10T09:48:13+00:00","remoteAddr":"147.86.223.240","user":"--","app":"PHP","method":"GET","url":"\\/owncloud\\/status.php","message":"fopen(\\/var\\/www\\/vhosts\\/e4p.ch\\/httpdocs\\/owncloud\\/config\\/config.php): failed to open stream: Permission denied at \\/var\\/www\\/vhosts\\/e4p.ch\\/httpdocs\\/owncloud\\/lib\\/private\\/Config.php#281"}PHP message: {"reqId":"c39b8ef0-f0d1-4618-907e-46896ea1e7ac","level":3,"time":"2020-11-10T09:48:13+00:00","remoteAddr":"147.86.223.240","user":"--","app":"PHP","method":"GET","url":"\\/owncloud\\/status.php","message":"chmod(): Operation not permitted at \\/var\\/www\\/vhosts\\/e4p.ch\\/httpdocs\\/owncloud\\/lib\\/private\\/Config.php#284"}PHP message: {"reqId":"c39b8ef0-f0d1-4618-907e-46896ea1e7ac","level":4,"time":"2020-11-10T09:48:13+00:00","remoteAddr":"147.86.223.240","user":"--","app":"remote","method":"GET","url":"\\/owncloud\\/status.php","message":"Can't write into config directory!"}'
<?php /** * @author Andreas Fischer * @author Christopher Schäpers * @author Frank Karlitschek * @author Joas Schilling * @author Jörn Friedrich Dreyer * @author Kristof Provost * @author Lukas Reschke * @author martin.mattel@diemattels.at * @author Masaki Kawabata Neto * @author Morris Jobke * @author Philipp Schaffrath * @author Thomas Müller * * @copyright Copyright (c) 2020, ownCloud GmbH * @license AGPL-3.0 * * This code is free software: you can redistribute it and/or modify * it under the terms of the GNU Affero General Public License, version 3, * as published by the Free Software Foundation. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU Affero General Public License for more details. * * You should have received a copy of the GNU Affero General Public License, version 3, * along with this program. If not, see * */ try { require_once __DIR__ . '/lib/base.php'; # show the version details based on config.php parameter, # but do not expose the servername in the public via url $values = \OCP\Util::getStatusInfo( null, \OC::$server->getConfig()->getSystemValue('show_server_hostname', false) !== true, \OC::$server->getConfig()->getSystemValue('use_relative_domain_name', false) === true ); if (OC::$CLI) { \print_r($values); } else { \header('Access-Control-Allow-Origin: *'); \header('Content-Type: application/json'); echo \json_encode($values); } } catch (\Throwable $ex) { try { OC_Response::setStatus(OC_Response::STATUS_INTERNAL_SERVER_ERROR); \OCP\Util::writeLog('remote', $ex->getMessage(), \OCP\Util::FATAL); } catch (\Throwable $ex2) { // log through the crashLog \header("{$_SERVER['SERVER_PROTOCOL']} 599 Broken"); \OC::crashLog($ex); \OC::crashLog($ex2); } } #### Browser log ``` Insert your browser log here, this could for example include: a) The javascript console log b) The network log c) ... ```
Ok, it seemed that there was a file ownership issue on the server. After resolving this OwnCloud setup exactly as I expected it to.
