I’ve Owncloud 10.0.10 (too old). And wish balance the charge but i have strange behavior. When access by browser the access is fine, but try from client aks me the password and not login.
Web access -> HA Proxy -> Nextcloud -> Fine
Desktop client -> HA Proxy -> Owncloud -> Not fine
My HAProxy configuration
global
stats socket /tmp/haproxysock level admin
tune.ssl.default-dh-param 2048
log 127.0.0.1 local2
defaults
# mode http
#log /dev/log local1 notice
log global
timeout connect 5000ms
timeout client 50000ms
timeout server 50000ms
option httpclose
option forwardfor except 127.0.0.0/8
option redispatch
option abortonclose
option httplog
option dontlognull
frontend http_owncloud
bind *:80
mode http
maxconn 1000
default_backend webservers
frontend https_owncloud
bind *:443 ssl crt /etc/haproxy/certs/cloud.domain.com.pem
mode http
reqadd X-Forwarded-Proto:\ https
rspadd Strict-Transport-Security:\ max-age=31536000;\ includeSubDomains;\ preload
backend webservers
mode http
balance roundrobin
stats enable
stats uri /haproxy?stats
stats refresh 30s
option httpchk
option httpclose
option forwardfor
server oc-web-new-01 172.31.x.x:80 check verify none
server oc-web-new-02 172.31.x.x:80 check verify none
http-response set-header Strict-Transport-Security max-age=16000000;\ includeSubDomains;\ preload;
http-request set-header X-Forwarded-Port %[dst_port]
http-request add-header X-Forwarded-Proto https if { ssl_fc }
My services
S.O Centos 7 (HA Proxy and Owncloud)
PHP 7.2.17 with FPM (For Owncloud webserver)
Owncloud version 10.0.10
HA Proxy 1.5.18
Desktop client 2.5.4 (stable)
And the client error:
