Please help us by providing the following info. Before posting please make sure that you're running the latest available version for your oC release: https://owncloud.org/changelog/ + https://owncloud.org/changelog/desktop/
1. Start Windows10 or Kubuntu 16.04 (Both 64bit)
2. Start the Desktop File Sync
3.
It should start to synchronize.
Error: Operation cancelled
Client version: 2.2.3
Client operating system: Win 10 & Kubuntu 16.04
Operating system: Raspbian
Web server: nginx
Database: idk
PHP version: dik
ownCloud version (see ownCloud admin page): 9.1.0 (stable)
Updated from an older ownCloud or fresh install: Updated from an older ownCloud
ErrorPHPInvalid argument supplied for foreach() at /var/www/owncloud/apps/apporder/util.php#552016-09-15T09:36:49+00:00FatalwebdavException:
{"Message":"HTTP\/1.1 503 Could not open
file","Exception":"Sabre\DAV\Exception\ServiceUnavailable","Code":0,"Trace":"#0\/var\/www\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(83):
OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]:
Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request),
Object(Sabre\HTTP\Response))\n#2
\/var\/www\/owncloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105):
call_user_func_array(Array, Array)\n#3
\/var\/www\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(459):
Sabre\Event\EventEmitter->emit('method:GET', Array)\n#4
\/var\/www\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(248):
Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request),
Object(Sabre\HTTP\Response))\n#5
\/var\/www\/owncloud\/apps\/dav\/appinfo\/v1\/webdav.php(56):
Sabre\DAV\Server->exec()\n#6 \/var\/www\/owncloud\/remote.php(164):
require_once('\/var\/www\/ownclo...')\n#7
{main}","File":"\/var\/www\/owncloud\/apps\/dav\/lib\/Connector\/Sabre\/File.php","Line":306,"User":"PatrickDavid"}2016-09-15T09:36:28+00:00ErrorPHPfopen(/var/www/owncloud/data/PatrickDavid/files/BackUps/PC/WIN10/07.08.2016/Musik/Alt/Akt
Musiksammlung/Latin Hits 2015 Club Edition - 60 Latin Music Hits
(Salsa, Bachata, D/2014/01-29- Puesto Pal Jangueo.mp3): failed to open
stream: No such file or directory at
/var/www/owncloud/lib/private/Files/Storage/Local.php#2732016-09-15T09:36:28+00:00FatalwebdavException:
{main}","File":"\/var\/www\/owncloud\/apps\/dav\/lib\/Connector\/Sabre\/File.php","Line":306,"User":"PatrickDavid"}2016-09-15T09:36:17+00:00ErrorPHPfopen(/var/www/owncloud/data/PatrickDavid/files/BackUps/PC/WIN10/07.08.2016/Musik/Alt/Akt
/var/www/owncloud/lib/private/Files/Storage/Local.php#2732016-09-15T09:36:17+00:00FatalwebdavException:
{main}","File":"\/var\/www\/owncloud\/apps\/dav\/lib\/Connector\/Sabre\/File.php","Line":306,"User":"PatrickDavid"}2016-09-15T08:20:04+00:00ErrorPHPfopen(/var/www/owncloud/data/PatrickDavid/files/BackUps/PC/WIN10/07.08.2016/Musik/Alt/Akt
/var/www/owncloud/lib/private/Files/Storage/Local.php#2732016-09-15T08:20:04+00:00FatalwebdavException:
{main}","File":"\/var\/www\/owncloud\/apps\/dav\/lib\/Connector\/Sabre\/File.php","Line":306,"User":"PatrickDavid"}2016-09-15T08:00:00+00:00ErrorPHPfopen(/var/www/owncloud/data/PatrickDavid/files/BackUps/PC/WIN10/07.08.2016/Musik/Alt/Akt
/var/www/owncloud/lib/private/Files/Storage/Local.php#2732016-09-15T08:00:00+00:00FatalwebdavException:
{main}","File":"\/var\/www\/owncloud\/apps\/dav\/lib\/Connector\/Sabre\/File.php","Line":306,"User":"PatrickDavid"}2016-09-15T07:58:54+00:00
