- Launch in http only, transmit big files OK
- Change the website in https
- Large files are transferred to the upload directory but the interface remains on file processing for files larger than 10 MB
Files must be uploaded and directory upload must be empty
Chunks of files remain in directories under /var/www/owncloud/data/user/uploads/
Operating system: Debian 10 (Buster)
Web server: Apache 2.4
Database: MariaDB Ver 15.1 Distrib 10.3.27-MariaDB
PHP version: PHP 7.3.27-1~deb10u1
ownCloud version: (see ownCloud admin page) 10.7.0.4
Where did you install ownCloud from: http://download.owncloud.org/download/repositories/production/Debian_10/
no
no
Chromium / Firefox ESR
Linux Debian Buster
[Fri May 14 13:39:13.597661 2021] [authz_core:error] [pid 25866] [client 192.168.0.250:42568] AH01630: client denied by server configuration: /var/www/owncloud/data/htaccesstest.txt
[Fri May 14 13:52:59.769110 2021] [authz_core:error] [pid 26958] [client 192.168.0.250:44006] AH01630: client denied by server configuration: /var/www/owncloud/data/htaccesstest.txt
[Fri May 14 14:10:54.433601 2021] [authz_core:error] [pid 26957] [client 192.168.0.250:45958] AH01630: client denied by server configuration: /var/www/owncloud/data/htaccesstest.txt
[Fri May 14 15:28:59.655067 2021] [authz_core:error] [pid 4375] [client 192.168.0.250:56304] AH01630: client denied by server configuration: /var/www/owncloud/data/htaccesstest.txt
https://gist.github.com/jdtissot/8a10728560fb03290d705830f89e9faa#file-apache-log
{“reqId”:“DZEqRziVPcCrbP1R1ck1”,“level”:1,“time”:“2021-05-14T12:00:02+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Invalidating tokens older than 2021-05-14T11:40:02+00:00”}
{“reqId”:“tUC0fJWLVIUuOfFMolED”,“level”:1,“time”:“2021-05-14T12:15:01+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Invalidating tokens older than 2021-05-14T11:55:01+00:00”}
{“reqId”:“4seLXrkzfsTu3BWH1IS0”,“level”:1,“time”:“2021-05-14T12:30:02+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Invalidating tokens older than 2021-05-14T12:10:02+00:00”}
{“reqId”:“6T9S2C9tQwqW361RbQFz”,“level”:1,“time”:“2021-05-14T12:45:02+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Invalidating tokens older than 2021-05-14T12:25:02+00:00”}
{“reqId”:“8caWWlBSmpLBG0LQWtNA”,“level”:1,“time”:“2021-05-14T13:00:01+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Invalidating tokens older than 2021-05-14T12:40:01+00:00”}
{“reqId”:“OXRJ4WkrcAjoPkVtumvc”,“level”:1,“time”:“2021-05-14T13:15:02+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Invalidating tokens older than 2021-05-14T12:55:02+00:00”}
{“reqId”:“9B2E2wNPswlWAQCN7p57”,“level”:2,“time”:“2021-05-14T13:16:50+00:00”,“remoteAddr”:“192.168.0.250”,“user”:“jdtissot”,“app”:“core”,“method”:“PUT”,“url”:"/owncloud/remote.php/dav/files/jdtissot/ISO/precision-t1700-workstation_Owner’s%20Manual_fr-fr.pdf",“message”:“ignoring lock release with type 1 for files/b3af948c7d1bc6b05d4be28b2e3d3526. Lock hasn’t been acquired before”}
{“reqId”:“9B2E2wNPswlWAQCN7p57”,“level”:2,“time”:“2021-05-14T13:16:50+00:00”,“remoteAddr”:“192.168.0.250”,“user”:“jdtissot”,“app”:“core”,“method”:“PUT”,“url”:"/owncloud/remote.php/dav/files/jdtissot/ISO/precision-t1700-workstation_Owner’s%20Manual_fr-fr.pdf",“message”:“ignoring lock release with type 1 for files/f7459e89701a7172a8f6b5cd7bcb2b7c. Lock hasn’t been acquired before”}
{“reqId”:“V8rpusvBnCO41BDHrEdE”,“level”:2,“time”:“2021-05-14T13:17:01+00:00”,“remoteAddr”:“192.168.0.250”,“user”:“jdtissot”,“app”:“core”,“method”:“PUT”,“url”:"/owncloud/remote.php/dav/files/jdtissot/ISO/Depouillement%20Eval%202019.pdf",“message”:“ignoring lock release with type 1 for files/b3c9d483d513d270079066f0d4d1ca1a. Lock hasn’t been acquired before”}
{“reqId”:“V8rpusvBnCO41BDHrEdE”,“level”:2,“time”:“2021-05-14T13:17:01+00:00”,“remoteAddr”:“192.168.0.250”,“user”:“jdtissot”,“app”:“core”,“method”:“PUT”,“url”:"/owncloud/remote.php/dav/files/jdtissot/ISO/Depouillement%20Eval%202019.pdf",“message”:“ignoring lock release with type 1 for files/f7459e89701a7172a8f6b5cd7bcb2b7c. Lock hasn’t been acquired before”}
{“reqId”:“Z6KlA0lPE7jZvjwZLadn”,“level”:1,“time”:“2021-05-14T13:30:01+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Invalidating tokens older than 2021-05-14T13:10:01+00:00”}
{“reqId”:“67i3SCFhkRiAxv18OCfM”,“level”:1,“time”:“2021-05-14T13:45:02+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Invalidating tokens older than 2021-05-14T13:25:02+00:00”}
{“reqId”:“dZWTwDcBhUc1gntPNcDV”,“level”:2,“time”:“2021-05-14T13:58:48+00:00”,“remoteAddr”:“192.168.0.250”,“user”:“admin”,“app”:“core”,“method”:“PUT”,“url”:"/owncloud/remote.php/dav/files/admin/Depouillement%20Eval%202019.pdf",“message”:“ignoring lock release with type 1 for files/02c294872c5810b7102da59171e65d49. Lock hasn’t been acquired before”}
{“reqId”:“cI4FuN7w8lk8mG1BnKTC”,“level”:1,“time”:“2021-05-14T14:00:01+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Invalidating tokens older than 2021-05-14T13:40:01+00:00”}
JQMIGRATE: Migrate is installed, version 1.4.0
DevTools failed to load SourceMap: Could not load content for chrome-extension://mmhlniccooihdimnnjhamobppdhaolme/lib/tp/browser-polyfill.min.js.map: HTTP error: status code 404, net::ERR_UNKNOWN_URL_SCHEME
26Refused to load the font '<URL>' because it violates the following Content Security Policy directive: "font-src 'self'".
js.js?v=2a622324a06c9374184c0ba1932ffab2:2329 Deprecation warning: tipsy is deprecated. Use tooltip instead.
jQuery.fn.tipsy @ js.js?v=2a622324a06c9374184c0ba1932ffab2:2329
(anonymous) @ file-upload.js?v=2a622324a06c9374184c0ba1932ffab2:1308
dispatch @ jquery.js:4435
r.handle @ jquery.js:4121
trigger @ jquery.js:4350
a.event.trigger @ jquery-migrate.min.js?v=2a622324a06c9374184c0ba1932ffab2:2
(anonymous) @ jquery.js:4901
each @ jquery.js:374
each @ jquery.js:139
trigger @ jquery.js:4900
_trigger @ jquery-ui.custom.js?v=2a622324a06c9374184c0ba1932ffab2:787
_beforeSend @ jquery.fileupload.js?v=2a622324a06c9374184c0ba1932ffab2:878
(anonymous) @ jquery-ui.custom.js?v=2a622324a06c9374184c0ba1932ffab2:405
_onSend @ jquery.fileupload.js?v=2a622324a06c9374184c0ba1932ffab2:994
data.submit @ jquery.fileupload.js?v=2a622324a06c9374184c0ba1932ffab2:721
(anonymous) @ file-upload.js?v=2a622324a06c9374184c0ba1932ffab2:286
(anonymous) @ jquery.js:3256
j @ jquery.js:3099
fireWith @ jquery.js:3211
(anonymous) @ jquery.js:3339
j @ jquery.js:3099
e.<computed> @ jquery.js:3301
(anonymous) @ client.js?v=2a622324a06c9374184c0ba1932ffab2:713
Promise.then (async)
_simpleCall @ client.js?v=2a622324a06c9374184c0ba1932ffab2:710
createDirectory @ client.js?v=2a622324a06c9374184c0ba1932ffab2:811
submit @ file-upload.js?v=2a622324a06c9374184c0ba1932ffab2:276
(anonymous) @ file-upload.js?v=2a622324a06c9374184c0ba1932ffab2:650
_.each._.forEach @ underscore.js?v=2a622324a06c9374184c0ba1932ffab2:186
submitUploads @ file-upload.js?v=2a622324a06c9374184c0ba1932ffab2:648
onNoConflicts @ file-upload.js?v=2a622324a06c9374184c0ba1932ffab2:1105
checkExistingFiles @ file-upload.js?v=2a622324a06c9374184c0ba1932ffab2:865
add @ file-upload.js?v=2a622324a06c9374184c0ba1932ffab2:1127
_trigger @ jquery-ui.custom.js?v=2a622324a06c9374184c0ba1932ffab2:789
(anonymous) @ jquery.fileupload.js?v=2a622324a06c9374184c0ba1932ffab2:1090
_onAdd @ jquery.fileupload.js?v=2a622324a06c9374184c0ba1932ffab2:1083
(anonymous) @ jquery.fileupload.js?v=2a622324a06c9374184c0ba1932ffab2:1289
j @ jquery.js:3099
add @ jquery.js:3145
always @ jquery.js:3246
_onChange @ jquery.fileupload.js?v=2a622324a06c9374184c0ba1932ffab2:1279
handlerProxy @ jquery-ui.custom.js?v=2a622324a06c9374184c0ba1932ffab2:706
start @ file-upload.js?v=2a622324a06c9374184c0ba1932ffab2:1140
j @ jquery.js:3099
j @ jquery.js:3099
j @ jquery.js:3099
client.js?v=2a622324a06c9374184c0ba1932ffab2:250 MOVE https://dmz-pve-srv05/owncloud/remote.php/dav/uploads/admin/web-file-upload-9ad3c5b2dbe62a4d2affb30dd0c37f4b-1621001220885/.file 404 (Not Found)
request @ client.js?v=2a622324a06c9374184c0ba1932ffab2:250
_moveOrCopy @ client.js?v=2a622324a06c9374184c0ba1932ffab2:749
move @ client.js?v=2a622324a06c9374184c0ba1932ffab2:837
done @ file-upload.js?v=2a622324a06c9374184c0ba1932ffab2:315
(anonymous) @ file-upload.js?v=2a622324a06c9374184c0ba1932ffab2:1385
_onDone @ jquery.fileupload.js?v=2a622324a06c9374184c0ba1932ffab2:914
(anonymous) @ jquery.fileupload.js?v=2a622324a06c9374184c0ba1932ffab2:960
j @ jquery.js:3099
(anonymous) @ jquery.fileupload.js?v=2a622324a06c9374184c0ba1932ffab2:844
j @ jquery.js:3099
x @ jquery.js:8264
(anonymous) @ jquery.js:8605
load (async)
send @ jquery.js:8622
ajax @ jquery.js:8166
upload @ jquery.fileupload.js?v=2a622324a06c9374184c0ba1932ffab2:818
(anonymous) @ jquery.fileupload.js?v=2a622324a06c9374184c0ba1932ffab2:842
j @ jquery.js:3099
x @ jquery.js:8264
load (async)
_chunkedUpload @ jquery.fileupload.js?v=2a622324a06c9374184c0ba1932ffab2:869
send @ jquery.fileupload.js?v=2a622324a06c9374184c0ba1932ffab2:958
j @ jquery.js:3099
(anonymous) @ jquery.js:3255
(anonymous) @ jquery.js:3252
a.Deferred @ jquery-migrate.min.js?v=2a622324a06c9374184c0ba1932ffab2:2
then @ jquery.js:3251
_onSend @ jquery.fileupload.js?v=2a622324a06c9374184c0ba1932ffab2:1003
j @ jquery.js:3099
j @ jquery.js:3099
j @ jquery.js:3099
client.js?v=2a622324a06c9374184c0ba1932ffab2:430 Uncaught (in promise) TypeError: Cannot read property 'getElementsByTagNameNS' of null
at Client._getSabreException (client.js?v=2a622324a06c9374184c0ba1932ffab2:430)
at client.js?v=2a622324a06c9374184c0ba1932ffab2:758
_getSabreException @ client.js?v=2a622324a06c9374184c0ba1932ffab2:430
(anonymous) @ client.js?v=2a622324a06c9374184c0ba1932ffab2:758
_moveOrCopy @ client.js?v=2a622324a06c9374184c0ba1932ffab2:753
j @ jquery.js:3099
j @ jquery.js:3099
x @ jquery.js:8264
load (async)
j @ jquery.js:3099
x @ jquery.js:8264
load (async)
j @ jquery.js:3099
j @ jquery.js:3099
j @ jquery.js:3099
j @ jquery.js:3099
