If i want to create a custom theme with the following script: https://doc.owncloud.org/server/10.0/developer_manual/core/theming.html?highlight=theme
the script cant find the read-config.php i also cant find the file in my owncloud system and the documentation. where can i get the file from?
Hm, I get the same error. Let me investigate and get back to you.
Thanks for raising this issue.
Okay, it was a build error in the documentation, a script “read-config.php” is missing. Error was fixed and will be included in the document after the next build.
Edit:
Done. Second script is now online, can you try and report back?
https://doc.owncloud.com/server/10.0/developer_manual/core/theming.html
Works, thank you!
