Ownclound don't start
Hello, i need help for the latest version on Owlcoud with Windows 10.
The application don’t start and i have this bug message :
“This application failed to start becauce no Qt Platform plugin could be initialized. Reinstalling the application may fix this problem.”
the reinstall of application doesn’t work.
thumb_550_default_image
Need help plz
What exact version? 2.7.3?
@NicolasLMS Pleas check: Did you install a 32bit build on a 64bit Win system?
https://github.com/owncloud/client/issues/8239
Please reinstall, there was an issue with the auto updater.
