Hello, I have been using ownCloud for about 9 months and I always get the same king of warning / error in the logs. I am not sure if this is something I should worry about as it looks like someone trying to access the server.
This as example:
{“reqId”:“Yxxxxxxxxxxxx-AUAAAAAM”,“level”:2,“time”:“2021-02-02T19:20:50+01:00”,“remoteAddr”:“xxx.xxx.30.53”,“user”:"–",“app”:“core”,“method”:“GET”,“url”:"/",“message”:“Trusted domain error. “xxx.xxx.30.53” tried to access using “hxxxxx.xxxxserver.net” as host.”}
I get many like this everyday from the beginning and with different IP addresses. ¿Is there anything else I should configure to avoid risks? I have set the HSTS and my domain is accessible with https.
Thanks in advance!
Ubuntu 18.04.5 LTS
Apache
10.6.0.5
