We’re seeing constant crashes on oCIS 6.2.0 on Ubuntu 24 with the following message:
panic: unaligned 64-bit atomic operation
This seems to always happen when we’re uploading files or creating new folders. Not sure how to debug this further as there’s no further information available on what’s causing the crash. Here are the last few debug lines immediately before the panic message:
unix-directory","mtime":{"seconds":1724654558,"nanos":343397049},"path":".","permission_set":{"add_grant":true,"create_container":true,"delete":true,"get_path":true,"initiate_file_download":true,"initiate_file_upload":true,"list_container":true,"list_recycle":true,"remove_grant":true,"purge_recycle":true,"restore_recycle_item":true,"stat":true},"size":626864,"owner":{"idp":"https://auth.example.org/realms/example","opaque_id":"0d4da3c4-fef9-4d16-b02b-35b954375043","type":1},"arbitrary_metadata":{"metadata":{"SAR:/lastmodified":"Mon, 26 Aug 2024 06:22:20 UTC","SAR:/lastmodified_server":"Mon, 26 Aug 2024 06:31:31 UTC","http://owncloud.org/ns/favorite":""}},"parent_id":{"space_id":"0d4da3c4-fef9-4d16-b02b-35b954375043"},"name":"Test User"},"time":"2024-08-26T06:42:39Z","line":"/home/ubuntu/ocis/vendor/github.com/cs3org/reva/v2/pkg/storage/utils/decomposedfs/node/node.go:824","message":"AsResourceInfo"}
Aug 26 06:42:39 ip-10-10-10-247 ocis[50798]: {"level":"debug","service":"storage-users","pkg":"rgrpc","traceid":"4ece1695f6441388e38f6a9e6b580352","permissions":{},"spaceid":"0d4da3c4-fef9-4d16-b02b-35b954375043","nodeid":"0d4da3c4-fef9-4d16-b02b-35b954375043","user":{"id":{"idp":"none","opaque_id":"9b8d978f-692c-4415-a85e-9f1d2bcb025b","type":3}},"time":"2024-08-26T06:42:39Z","line":"/home/ubuntu/ocis/vendor/github.com/cs3org/reva/v2/pkg/storage/utils/decomposedfs/node/node.go:1075","message":"returning aggregated permissions"}
Aug 26 06:42:39 ip-10-10-10-247 ocis[50798]: {"level":"debug","service":"storage-users","pkg":"rgrpc","traceid":"4ece1695f6441388e38f6a9e6b580352","spaceid":"0d4da3c4-fef9-4d16-b02b-35b954375043","nodeid":"0d4da3c4-fef9-4d16-b02b-35b954375043","nodepath":"/home/ocis/.ocis/storage/users/spaces/0d/4da3c4-fef9-4d16-b02b-35b954375043/nodes/0d/4d/a3/c4/-fef9-4d16-b02b-35b954375043","time":"2024-08-26T06:42:39Z","line":"/home/ubuntu/ocis/vendor/github.com/cs3org/reva/v2/pkg/storage/utils/decomposedfs/node/node.go:888","message":"quota not set"}
Aug 26 06:42:39 ip-10-10-10-247 ocis[50798]: {"level":"debug","service":"storage-users","pkg":"rgrpc","traceid":"4ece1695f6441388e38f6a9e6b580352","spaceid":"0d4da3c4-fef9-4d16-b02b-35b954375043","nodeid":"0d4da3c4-fef9-4d16-b02b-35b954375043","ri":{"type":2,"id":{"opaque_id":"0d4da3c4-fef9-4d16-b02b-35b954375043","space_id":"0d4da3c4-fef9-4d16-b02b-35b954375043"},"etag":"\"b1881bf9419ebde793f79747969d49cd\"","mime_type":"httpd/unix-directory","mtime":{"seconds":1724654558,"nanos":343397049},"path":".","permission_set":{},"size":626864,"owner":{"idp":"https://auth.example.org/realms/example","opaque_id":"0d4da3c4-fef9-4d16-b02b-35b954375043","type":1},"arbitrary_metadata":{},"parent_id":{"space_id":"0d4da3c4-fef9-4d16-b02b-35b954375043"},"name":"Test User"},"time":"2024-08-26T06:42:39Z","line":"/home/ubuntu/ocis/vendor/github.com/cs3org/reva/v2/pkg/storage/utils/decomposedfs/node/node.go:824","message":"AsResourceInfo"}
Aug 26 06:42:39 ip-10-10-10-247 ocis[50798]: {"level":"debug","service":"storage-users","pkg":"rgrpc","traceid":"4ece1695f6441388e38f6a9e6b580352","user-agent":"grpc-go/1.65.0","from":"tcp://127.0.0.1:56820","uri":"/cs3.storage.provider.v1beta1.ProviderAPI/Stat","start":"26/Aug/2024:06:42:39 +0000","end":"26/Aug/2024:06:42:39 +0000","time_ns":235297,"code":"OK","time":"2024-08-26T06:42:39Z","line":"/home/ubuntu/ocis/vendor/github.com/cs3org/reva/v2/internal/grpc/interceptors/log/log.go:69","message":"unary"}
Aug 26 06:42:39 ip-10-10-10-247 ocis[50798]: {"level":"debug","service":"gateway","pkg":"rgrpc","traceid":"4ece1695f6441388e38f6a9e6b580352","user-agent":"grpc-go/1.65.0","from":"tcp://127.0.0.1:48318","uri":"/cs3.gateway.v1beta1.GatewayAPI/Stat","start":"26/Aug/2024:06:42:39 +0000","end":"26/Aug/2024:06:42:39 +0000","time_ns":938948,"code":"OK","time":"2024-08-26T06:42:39Z","line":"/home/ubuntu/ocis/vendor/github.com/cs3org/reva/v2/internal/grpc/interceptors/log/log.go:69","message":"unary"}
Any ideas on what’s going wrong or how we can find a solution to keep this from happening?
