- Passwords resets not working for users via WebUI
- Password Changes as admin isn’t working for users
- Command Line wont take password reset command
Ubuntu 20
root@Owncloud-22:/var/www/owncloud/config# cat config.php
<?php
$CONFIG = array (
'passwordsalt' => '6Ez5hmelnHXwel6JWptSHwJ1NMiUtB',
'secret' => 'd5Bls24dHNdRgKi9hcHEjCPTZ60mja182o1l22QmyEqe5TFr',
'trusted_domains' =>
array (
0 => 'localhost',
1 => '20.124.5.128',
2 => 'mywebsite.com',
'datadirectory' => '/var/www/owncloud/data',
'overwrite.cli.url' => 'mywebsite.com',
'dbtype' => 'mysql',
'version' => '10.9.0.3',
'dbname' => 'owncloud',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'mysql.utf8mb4' => true,
'dbuser' => 'owncloud',
'dbpassword' => '******',
'allow_user_to_change_mail_address' => '',
'logtimezone' => 'UTC',
'apps_paths' =>
array (
0 =>
array (
'url' => '/apps',
'writable' => false,
1 =>
array (
'path' => '/var/www/owncloud/apps-external',
'url' => '/apps-external',
'writable' => true,
'installed' => true,
'instanceid' => 'ocg9w8vy2pqn',
'redis' =>
array (
'host' => '127.0.0.1',
'port' => '6379',
'theme' => '',
'loglevel' => 0,
'maintenance' => false,
'mail_domain' => 'mysite.com',
'mail_from_address' => 'ncdbanotifications',
'mail_smtpmode' => 'smtp',
'mail_smtpauth' => 1,
'mail_smtphost' => 'smtp.gmail.com',
'mail_smtpport' => '465',
'mail_smtpname' => '****@email',
'mail_smtppassword' => '********',
'enable_certificate_management' => true,
'mail_smtpsecure' => 'ssl',
**List of activated apps:**
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
