PAUTH authentication: domain user (its info are blank) and set a default group for new users
  1. Login by PWAUTH (kerberos with Windows Active Directory or LDAP);
I would like the information on the users in owncloud to be the same as the domain user information and, at first login, the user group should be the one I set before;
now user info are blank and user group, at first login, is “default”;
debian 8
apache 2
mysql 5.5
8.1.9
download the tar file from owncloud site
config.php
(the command sudo -u www-data php occ config: list system generates this: “[InvalidArgumentException] There are no commands defined in the config namespace.”
Apps Enabled:
  • activity: 2.0.2
  • documents: 0.10.2
  • files: 1.1.10
  • files_locking:
  • files_pdfviewer: 0.7.1
  • files_sharing: 0.6.3
  • files_texteditor: 0.4
  • files_trashbin: 0.6.3
  • files_versions: 1.0.6
  • files_videoviewer: 0.1.3
  • firstrunwizard: 1.1
  • gallery: 0.6.0
  • provisioning_api: 0.2
  • templateeditor: 0.1
  • updater: 0.6
  • user_external: 0.4
    Disabled:
  • encryption
  • external
  • files_antivirus
  • files_external
  • user_ldap
  • user_webdavauth
Are you using encryption: no
Are you using an external user-backend, if yes which one: kerberos
chrome
win 7
Thanks!!!
Personally i would upgrade to a recent / supported version of ownCloud first.
thanks, but for certain reasons i must use this version!! :slight_smile:
What reasons could justify running an outdated version which contains well known bugs and security issues which won’t be fixed ever?
Who knows that your issues are not related / caused by that outdated version?
:slight_smile:
