- settings (file size etc.) are correctly set with the web interface or desktop application
2.Try to upload anything or even make a new text file from the ios application
3.through web interface or desktop application (OSX), uploading is not a problem
Files get uploaded
Independent on the directory I choose, I get "a “no permission” error (german: Berechtigungsfehler)
From my provider - no admin rights on it.
mySQL
From my provider
ownCloud version:
8.2 I guess (where can I see this?)
Client
iOS version:
ownCloud app version:
Device model:
Not available```
{“reqId”:“WbEtZn8AAAIAAHXQglQAAAAg”,“remoteAddr”:“62.23.117.21”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 404 File with name InstantUpload\/Photo-2017-08-24-21-22-59_1719.JPG could not be located","Exception":"Sabre\\DAV\\Exception\\NotFound","Code":0,"Trace":"#0 \/home\/www\/web453\/html\/zcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(920): OC\\Connector\\Sabre\\ObjectTree->getNodeForPath(‘InstantUpload\/P…’)\n#1 \/home\/www\/web453\/html\/zcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(327): Sabre\\DAV\\Server->getPropertiesForPath(‘InstantUpload\/P…’, Array, 0)\n#2 [internal function]: Sabre\\DAV\\CorePlugin->httpPropfind(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#3 \/home\/www\/web453\/html\/zcloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 \/home\/www\/web453\/html\/zcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(469): Sabre\\Event\\EventEmitter->emit(‘method:PROPFIND’, Array)\n#5 \/home\/www\/web453\/html\/zcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#6 \/home\/www\/web453\/html\/zcloud\/apps\/files\/appinfo\/remote.php(56): Sabre\\DAV\\Server->exec()\n#7 \/home\/www\/web453\/html\/zcloud\/remote.php(149): require_once(‘\/home\/www\/web45…’)\n#8 {main}","File":"\/home\/www\/web453\/html\/zcloud\/lib\/private\/connector\/sabre\/objecttree.php","Line":159}”,“level”:0,“time”:“2017-09-07T11:28:38+00:00”,“method”:“PROPFIND”,“url”:“/zcloud/remote.php/webdav/InstantUpload/Photo-2017-08-24-21-22-59_1719.JPG”}
{“reqId”:“WbEti38AAAIAAALhTP0AAAAG”,“remoteAddr”:“185.46.214.75”,“app”:“core”,“message”:“Generating preview for "/InstantUpload/IMG_1411.jpg" with "OC\Preview\JPEG"”,“level”:0,“time”:“2017-09-07T11:29:15+00:00”,“method”:“GET”,“url”:“/zcloud/index.php/core/preview.png?file=%2FInstantUpload%2FIMG_1411.jpg&c=2bebc019eb0a69f989edfee345a8e03c&x=32&y=32&forceIcon=0”}
{“reqId”:“WbEti38AAAIAAALhTP0AAAAG”,“remoteAddr”:“185.46.214.75”,“app”:“core”,“message”:“OC_Image->fixOrientation() Orientation: 1”,“level”:0,“time”:“2017-09-07T11:29:15+00:00”,“method”:“GET”,“url”:“/zcloud/index.php/core/preview.png?file=%2FInstantUpload%2FIMG_1411.jpg&c=2bebc019eb0a69f989edfee345a8e03c&x=32&y=32&forceIcon=0”}
{“reqId”:“WbEu538AAAIAAApUuRYAAAAF”,“remoteAddr”:“62.23.117.21”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 404 File with name InstantUpload\/Neue Textdatei.txt could not be located","Exception":"Sabre\\DAV\\Exception\\NotFound","Code":0,"Trace":"#0 \/home\/www\/web453\/html\/zcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(920): OC\\Connector\\Sabre\\ObjectTree->getNodeForPath(‘InstantUpload\/N…’)\n#1 \/home\/www\/web453\/html\/zcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(327): Sabre\\DAV\\Server->getPropertiesForPath(‘InstantUpload\/N…’, Array, 0)\n#2 [internal function]: Sabre\\DAV\\CorePlugin->httpPropfind(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#3 \/home\/www\/web453\/html\/zcloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 \/home\/www\/web453\/html\/zcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(469): Sabre\\Event\\EventEmitter->emit(‘method:PROPFIND’, Array)\n#5 \/home\/www\/web453\/html\/zcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#6 \/home\/www\/web453\/html\/zcloud\/apps\/files\/appinfo\/remote.php(56): Sabre\\DAV\\Server->exec()\n#7 \/home\/www\/web453\/html\/zcloud\/remote.php(149): require_once(‘\/home\/www\/web45…’)\n#8 {main}","File":"\/home\/www\/web453\/html\/zcloud\/lib\/private\/connector\/sabre\/objecttree.php","Line":159}”,“level”:0,“time”:“2017-09-07T11:35:03+00:00”,“method”:“PROPFIND”,“url”:“/zcloud/remote.php/webdav/InstantUpload/Neue%20Textdatei.txt”}
{“reqId”:“WbEu6H8AAAIAAAL5dG0AAAAY”,“remoteAddr”:“62.23.117.21”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 404 File with name InstantUpload\/Neue Textdatei.txt could not be located","Exception":"Sabre\\DAV\\Exception\\NotFound","Code":0,"Trace":"#0 \/home\/www\/web453\/html\/zcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(920): OC\\Connector\\Sabre\\ObjectTree->getNodeForPath(‘InstantUpload\/N…’)\n#1 \/home\/www\/web453\/html\/zcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(327): Sabre\\DAV\\Server->getPropertiesForPath(‘InstantUpload\/N…’, Array, 0)\n#2 [internal function]: Sabre\\DAV\\CorePlugin->httpPropfind(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#3 \/home\/www\/web453\/html\/zcloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 \/home\/www\/web453\/html\/zcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(469): Sabre\\Event\\EventEmitter->emit(‘method:PROPFIND’, Array)\n#5 \/home\/www\/web453\/html\/zcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#6 \/home\/www\/web453\/html\/zcloud\/apps\/files\/appinfo\/remote.php(56): Sabre\\DAV\\Server->exec()\n#7 \/home\/www\/web453\/html\/zcloud\/remote.php(149): require_once(‘\/home\/www\/web45…’)\n#8 {main}","File":"\/home\/www\/web453\/html\/zcloud\/lib\/private\/connector\/sabre\/objecttree.php","Line":159}”,“level”:0,“time”:“2017-09-07T11:35:04+00:00”,“method”:“PROPFIND”,“url”:“/zcloud/remote.php/webdav/InstantUpload/Neue%20Textdatei.txt”}
{“reqId”:“WbEwRH8AAAIAABmM5pEAAAAQ”,“remoteAddr”:“185.46.214.75”,“app”:“DeleteOrphanedSharesJob”,“message”:“0 orphaned share(s) deleted”,“level”:0,“time”:“2017-09-07T11:40:53+00:00”,“method”:“GET”,“url”:“/zcloud/cron.php”}
## If you have suggestions of enhancements
### Tell us what could be improved:
I have seen similar issues, but none of them solved or directed to a "common guide" to new guys to owncloud like myself.
