Guys,
I had some problems overy my PHP version on my server. I have set 7.2 for every virtual server that i have and that made owncloud to work.
I used a web update and it crashed somehow after some time leaving me with message on logon saying that permissions are not correct. So i’ve decided to use the script from the website which made it even worse. Now I am getting “File not found” and that’s it. After working with the correct links in the script I get the below.
Can you help me sort this out? I’m 2 seconds from setting up nextcloud on docker.
Here is the main dir:
Dont bash on doing shit on root - I know
Operating system: Ubuntu 18.04
Web server: apache2 build with Virtualmin and Webmin
PHP version: 7.2
ownCloud version: 10
Where did you install ownCloud from: webpage
Cannot be done
Cannot be done
Check screenshot.
