Hi
I am on Debian Stable and my owncloud installation is giving me the above error. I have installed the module php-intl and when I do a php -m intl is listed as a module…
I have restarted the apache server… Any ideas ?
J
Hi
J
quick google search:
You have to enable this module after installing it:
If the extension is already installed you should try to enable it. Either in the php.ini file or from command line.
Syntax:
php:
phpenmod [mod name]
apache:
a2enmod [mod name]
Maybe the PHP version on the command line is not the same PHP version running by Apache?
That was it. I was running php5 for Apache and php7 for CLI.
Thanks!
J
