I am trying to configure owncloud 10.2 with primary storage in amazon s3. Following this documentation
https://doc.owncloud.com/server/admin_manual/enterprise/external_storage/s3_swift_as_primary_object_store_configuration.html
but when I try to enter I get the following error:
Internal Server Error
The server has encountered an error and can not complete the request.
Please contact the server administrator if this error appears more times, and include the technical details in your report below.
Technical details
Remote address: 95.63.110.38
ID of the application: DQuW4rox173Y9XsWbEEo
Type: Error
Code: 0
Message: Class ‘OCA \ Files_Primary_S3 \ S3Storage’ not found
File: /var/www/owncloud/lib/private/legacy/util.php
Line: 112
Traces
0 /var/www/owncloud/lib/private/legacy/util.php(279): OC_Util :: initObjectStoreRootFS (Array)
1 /var/www/owncloud/lib/base.php(908): OC_Util :: setupFS ()
2 /var/www/owncloud/index.php(54): OC :: handleRequest ()
3 {main}
The output of the php occ config command is:
#0 /var/www/owncloud/lib/private/legacy/util.php(279): OC_Util::initObjectStoreRootFS(Array)
#1 /var/www/owncloud/lib/private/Files/Filesystem.php(264): OC_Util::setupFS(’’)
#2 /var/www/owncloud/apps/files_sharing/lib/AppInfo/Application.php(109): OC\Files\Filesystem::getMountManager()
#3 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OCA\Files_Sharing\AppInfo\Application->OCA\Files_Sharing\AppInfo{closure}(Object(OC\AppFramework\DependencyInjection\DIContainer))
#4 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet(‘ExternalManager’)
#5 /var/www/owncloud/apps/federatedfilesharing/lib/AppInfo/Application.php(167): OC\AppFramework\Utility\SimpleContainer->query(‘ExternalManager’)
#6 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OCA\FederatedFileSharing\AppInfo\Application->OCA\FederatedFileSharing\AppInfo{closure}(Object(OC\AppFramework\DependencyInjection\DIContainer))
#7 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet(‘OCA\FederatedFi…’)
#8 /var/www/owncloud/lib/private/ServerContainer.php(79): OC\AppFramework\Utility\SimpleContainer->query(‘OCA\FederatedFi…’)
#9 /var/www/owncloud/lib/private/Console/Application.php(167): OC\ServerContainer->query(‘OCA\FederatedFi…’)
#10 /var/www/owncloud/lib/private/Console/Application.php(108): OC\Console\Application->loadCommandsFromInfoXml(Array)
#11 /var/www/owncloud/console.php(105): OC\Console\Application->loadCommands(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#12 /var/www/html/vocces/occ(11): require_once(’/var/www/html/v…’)
#13 {main}
Any suggestions?
