Problem after updating
after updating i became the error:
Warning: flock() expects parameter 1 to be resource, boolean given in /www/htdocs/*********/cloud.brilon-lumberjacks.com/lib/private/config.php on line 198
Fatal error: Call to a member function getLogger() on null in /www/htdocs/********/cloud.brilon-lumberjacks.com/lib/public/util.php on line 166
i dont have ssh Login, only ftp. how can i fix it ?
Between which versions did you upgrade?
Did you remove all old script-files before (delete everything except the config/ and data/ folder)?
it was the Auto update from 7 to 8. i think, i cant remember
i remove nothing before or after
The updater app is not so reliable, especially if you have to do several major upgrades. Do a manual upgrade, from OC 7.0 your upgrade path is: 7.0.x → 7.0.15 → 8.0.14 → 8.1.9 → 8.2.7 → 9.0.4.
Check your config/config.php which version is currently installed. Make a backup of your data and database. Then:
  • Delete everything except data/ and config/ folder
  • Download the new version (Changelog - ownCloud) and extract the zip file in your FTP folder
  • Open owncloud in your browser and run the upgrade
  • Activate all apps you used, there are often updates between the versions as well
  • Repeat the procedure for the next upgrade
to easy… thanks for Support…
