hi , i am new with OC , i m using owncloud on debian server 8.5 ,i did all the installation correctly , and the integration with LDapserver to allow my LDap users to acces owncloud , after that
when I tried to log on the browser , the server is allways frozen in authentication step ( it takes long minutes ) than it sends me this error :
(( Problem loading page, reloading in 5 seconds ))
and i get white page , and if I click on the cancel button (X) on the browser , I will have the home page of owncloud but i cant do any thing on it ,
can you please tell me the possible causes for this error and how to fix them , I will be thankful
here is my leg file for the last day :
> ( Error core Exception: {"Exception":"Doctrine\\DBAL\\Exception\\DriverException","Message":"An exception occurred while executing 'SELECT `uid`, `displayname` FROM `oc_users` WHERE LOWER(`uid`) = LOWER(?)' with params [\"admin\"]:\n\nSQLSTATE[HY000]: General error: 2006 MySQL server has gone away","Code":0,"Trace":"#0 \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DBALException.php(116): Doctrine\\DBAL\\Driver\\AbstractMySQLDriver->convertException('An exception oc...', Object(Doctrine\\DBAL\\Driver\\PDOException))\n#1 \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Statement.php(175): Doctrine\\DBAL\\DBALException::driverExceptionDuringQuery(Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Object(Doctrine\\DBAL\\Driver\\PDOException), 'SELECT `uid`, `...', Array)\n#2 \/var\/www\/owncloud\/lib\/private\/legacy\/db\/statementwrapper.php(73): Doctrine\\DBAL\\Statement->execute(Array)\n#3 \/var\/www\/owncloud\/lib\/private\/User\/Database.php(223): OC_DB_StatementWrapper->execute(Array)\n#4 \/var\/www\/owncloud\/lib\/private\/User\/Database.php(270): OC\\User\\Database->loadUser('admin')\n#5 \/var\/www\/owncloud\/lib\/private\/User\/Manager.php(139): OC\\User\\Database->userExists('admin')\n#6 \/var\/www\/owncloud\/lib\/private\/User\/Session.php(192): OC\\User\\Manager->get('admin')\n#7 \/var\/www\/owncloud\/lib\/private\/legacy\/app.php(288): OC\\User\\Session->getUser()\n#8 \/var\/www\/owncloud\/lib\/private\/legacy\/app.php(105): OC_App::getEnabledApps()\n#9 \/var\/www\/owncloud\/lib\/private\/legacy\/user.php(127): OC_App::loadApps(Array)\n#10 \/var\/www\/owncloud\/lib\/base.php(640): OC_User::setupBackends()\n#11 \/var\/www\/owncloud\/lib\/base.php(967): OC::init()\n#12 \/var\/www\/owncloud\/index.php(37): require_once('\/var\/www\/ownclo...')\n#13 {main}","File":"\/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/AbstractMySQLDriver.php","Line":115} 2016-09-19T04:25:05+00:00
Error index Exception: {"Exception":"Doctrine\\DBAL\\Exception\\DriverException","Message":"An exception occurred while executing 'SELECT `uid`, `displayname` FROM `oc_users` WHERE LOWER(`uid`) = LOWER(?)' with params [\"admin\"]:\n\nSQLSTATE[HY000]: General error: 2006 MySQL server has gone away","Code":0,"Trace":"#0 \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DBALException.php(116): Doctrine\\DBAL\\Driver\\AbstractMySQLDriver->convertException('An exception oc...', Object(Doctrine\\DBAL\\Driver\\PDOException))\n#1 \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Statement.php(175): Doctrine\\DBAL\\DBALException::driverExceptionDuringQuery(Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Object(Doctrine\\DBAL\\Driver\\PDOException), 'SELECT `uid`, `...', Array)\n#2 \/var\/www\/owncloud\/lib\/private\/legacy\/db\/statementwrapper.php(73): Doctrine\\DBAL\\Statement->execute(Array)\n#3 \/var\/www\/owncloud\/lib\/private\/User\/Database.php(223): OC_DB_StatementWrapper->execute(Array)\n#4 \/var\/www\/owncloud\/lib\/private\/User\/Database.php(270): OC\\User\\Database->loadUser('admin')\n#5 \/var\/www\/owncloud\/lib\/private\/User\/Manager.php(139): OC\\User\\Database->userExists('admin')\n#6 \/var\/www\/owncloud\/lib\/private\/User\/Session.php(192): OC\\User\\Manager->get('admin')\n#7 \/var\/www\/owncloud\/lib\/private\/legacy\/app.php(288): OC\\User\\Session->getUser()\n#8 \/var\/www\/owncloud\/lib\/private\/legacy\/app.php(105): OC_App::getEnabledApps()\n#9 \/var\/www\/owncloud\/lib\/private\/legacy\/user.php(127): OC_App::loadApps(Array)\n#10 \/var\/www\/owncloud\/lib\/base.php(640): OC_User::setupBackends()\n#11 \/var\/www\/owncloud\/lib\/base.php(967): OC::init()\n#12 \/var\/www\/owncloud\/index.php(37): require_once('\/var\/www\/ownclo...')\n#13 {main}","File":"\/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/AbstractMySQLDriver.php","Line":115} 2016-09-19T04:25:05+00:00
Error PHP Error while sending QUERY packet. PID=18467 at /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php#91 2016-09-19T04:25:05+00:00
Error core Exception: {"Exception":"Doctrine\\DBAL\\Exception\\DriverException","Message":"An exception occurred while executing 'SELECT `uid`, `displayname` FROM `oc_users` WHERE LOWER(`uid`) = LOWER(?)' with params [\"admin\"]:\n\nSQLSTATE[HY000]: General error: 2006 MySQL server has gone away","Code":0,"Trace":"#0 \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DBALException.php(116): Doctrine\\DBAL\\Driver\\AbstractMySQLDriver->convertException('An exception oc...', Object(Doctrine\\DBAL\\Driver\\PDOException))\n#1 \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Statement.php(175): Doctrine\\DBAL\\DBALException::driverExceptionDuringQuery(Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Object(Doctrine\\DBAL\\Driver\\PDOException), 'SELECT `uid`, `...', Array)\n#2 \/var\/www\/owncloud\/lib\/private\/legacy\/db\/statementwrapper.php(73): Doctrine\\DBAL\\Statement->execute(Array)\n#3 \/var\/www\/owncloud\/lib\/private\/User\/Database.php(223): OC_DB_StatementWrapper->execute(Array)\n#4 \/var\/www\/owncloud\/lib\/private\/User\/Database.php(270): OC\\User\\Database->loadUser('admin')\n#5 \/var\/www\/owncloud\/lib\/private\/User\/Manager.php(139): OC\\User\\Database->userExists('admin')\n#6 \/var\/www\/owncloud\/lib\/private\/User\/Session.php(192): OC\\User\\Manager->get('admin')\n#7 \/var\/www\/owncloud\/lib\/private\/L10N\/Factory.php(131): OC\\User\\Session->getUser()\n#8 \/var\/www\/owncloud\/lib\/private\/legacy\/l10n.php(312): OC\\L10N\\Factory->findLanguage('search')\n#9 \/var\/www\/owncloud\/lib\/private\/legacy\/util.php(506): OC_L10N::findLanguage('search')\n#10 \/var\/www\/owncloud\/lib\/private\/legacy\/util.php(479): OC_Util::addTranslations('search')\n#11 \/var\/www\/owncloud\/lib\/private\/legacy\/template.php(137): OC_Util::addScript('search', 'search', true)\n#12 \/var\/www\/owncloud\/lib\/private\/legacy\/template.php(75): OC_Template::initTemplateEngine('error')\n#13 \/var\/www\/owncloud\/lib\/private\/legacy\/template.php(348): OC_Template->__construct('', 'exception', 'error', false)\n#14 \/var\/www\/owncloud\/index.php(55): OC_Template::printExceptionErrorPage(Object(Doctrine\\DBAL\\Exception\\DriverException))\n#15 {main}","File":"\/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/AbstractMySQLDriver.php","Line":115} 2016-09-19T04:25:05+00:00
Error PHP Doctrine\DBAL\Exception\DriverException: An exception occurred while executing 'SELECT `uid`, `displayname` FROM `oc_users` WHERE LOWER(`uid`) = LOWER(?)' with params ["admin"]: SQLSTATE[HY000]: General error: 2006 MySQL server has gone away at /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php#115 2016-09-19T04:25:05+00:00
Error PHP Error while sending QUERY packet. PID=17836 at /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php#91 2016-09-19T04:25:05+00:00
Error PHP Error while sending QUERY packet. PID=18859 at /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php#91 2016-09-19T04:25:05+00:00
Error PHP Error while sending QUERY packet. PID=18853 at /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php#91 2016-09-19T04:25:05+00:00
Error PHP Error while sending QUERY packet. PID=18464 at /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php#91 2016-09-19T04:25:05+00:00
Error PHP Error while sending QUERY packet. PID=18899 at /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php#91 2016-09-19T04:25:05+00:00
Error PHP Error while sending QUERY packet. PID=17833 at /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php#91 2016-09-19T04:25:05+00:00
Error index Exception: {"Exception":"Doctrine\\DBAL\\Exception\\DriverException","Message":"An exception occurred while executing 'SELECT `uid`, `displayname` FROM `oc_users` WHERE LOWER(`uid`) = LOWER(?)' with params [\"admin\"]:\n\nSQLSTATE[HY000]: General error: 2006 MySQL server has gone away","Code":0,"Trace":"#0 \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DBALException.php(116): Doctrine\\DBAL\\Driver\\AbstractMySQLDriver->convertException('An exception oc...', Object(Doctrine\\DBAL\\Driver\\PDOException))\n#1 \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Statement.php(175): Doctrine\\DBAL\\DBALException::driverExceptionDuringQuery(Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Object(Doctrine\\DBAL\\Driver\\PDOException), 'SELECT `uid`, `...', Array)\n#2 \/var\/www\/owncloud\/lib\/private\/legacy\/db\/statementwrapper.php(73): Doctrine\\DBAL\\Statement->execute(Array)\n#3 \/var\/www\/owncloud\/lib\/private\/User\/Database.php(223): OC_DB_StatementWrapper->execute(Array)\n#4 \/var\/www\/owncloud\/lib\/private\/User\/Database.php(270): OC\\User\\Database->loadUser('admin')\n#5 \/var\/www\/owncloud\/lib\/private\/User\/Manager.php(139): OC\\User\\Database->userExists('admin')\n#6 \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Statement.php(175): Doctrine\\DBAL\\DBALException::driverExceptionDuringQuery(Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Object(Doctrine\\DBAL\\Driver\\PDOException), 'SELECT `uid`, `...', Array)\n#2 \/var\/www\/owncloud\/lib\/private\/legacy\/db\/statementwrapper.php(73): Doctrine\\DBAL\\Statement->execute(Array)\n#3 \/var\/www\/owncloud\/lib\/private\/User\/Database.php(223): OC_DB_StatementWrapper->execute(Array)\n#4 \/var\/www\/owncloud\/lib\/private\/User\/Database.php(270): OC\\User\\Database->loadUser('admin')\n#5 \/var\/www\/owncloud\/lib\/private\/User\/Manager.php(139): OC\\User\\Database->userExists('admin')\n#6 \/var\/www\/owncloud\/lib\/private\/User\/Session.php(192): OC\\User\\Manager->get('admin')\n#7 \/var\/www\/owncloud\/lib\/private\/L10N\/Factory.php(131): OC\\User\\Session->getUser()\n#8 \/var\/www\/owncloud\/lib\/private\/legacy\/l10n.php(312): OC\\L10N\\Factory->findLanguage('search')\n#9 \/var\/www\/owncloud\/lib\/private\/legacy\/util.php(506): OC_L10N::findLanguage('search')\n#10 \/var\/www\/owncloud\/lib\/private\/legacy\/util.php(479): OC_Util::addTranslations('search')\n#11 \/var\/www\/owncloud\/lib\/private\/legacy\/template.php(137): OC_Util::addScript('search', 'search', true)\n#12 \/var\/www\/owncloud\/lib\/private\/legacy\/template.php(75): OC_Template::initTemplateEngine('error')\n#13 \/var\/www\/owncloud\/lib\/private\/legacy\/template.php(348): OC_Template->__construct('', 'exception', 'error', false)\n#14 \/var\/www\/owncloud\/index.php(55): OC_Template::printExceptionErrorPage(Object(Doctrine\\DBAL\\Exception\\DriverException))\n#15 {main}","File":"\/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/AbstractMySQLDriver.php","Line":115} 2016-09-19T04:25:05+00:00
Error PHP Error while sending QUERY packet. PID=18719 at /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php#91 2016-09-19T04:25:05+00:00
Error PHP Error while sending QUERY packet. PID=18298 at /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php#91 2016-09-19T04:25:05+00:00
Error PHP Doctrine\DBAL\Exception\DriverException: An exception occurred while executing 'SELECT `gid` FROM `oc_groups` WHERE `gid` = ?' with params ["mohammed"]: SQLSTATE[HY000]: General error: 2006 MySQL server has gone away at /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php#115 2016-09-19T04:25:05+00:00
Fatal cron An exception occurred while executing 'UPDATE `oc_jobs` SET `reserved_at` = '0' WHERE `id` = ?' with params ["14"]: SQLSTATE[HY000]: General error: 2006 MySQL server has gone away 2016-09-19T04:25:05+00:00
Error PHP Doctrine\DBAL\Exception\DriverException: An exception occurred while executing 'SELECT `gid` FROM `oc_groups` WHERE `gid` = ?' with params ["m"]: SQLSTATE[HY000]: General error: 2006 MySQL server has gone away at /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php#115 2016-09-19T04:25:05+00:00
Error PHP Error while sending QUERY packet. PID=18850 at /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php#91 2016-09-19T04:25:05+00:00
Error PHP Error while sending QUERY packet. PID=18722 at /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php#91 2016-09-19T04:25:05+00:00
Error PHP Error while sending QUERY packet. PID=17830 at /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php#91 2016-09-19T04:25:05+00:00
Error user_ldap Attempt for Paging? 1 2016-09-19T04:25:05+00:00
Error user_ldap Error when searching: Can't contact LDAP server code -1 2016-09-19T04:25:05+00:00
Error PHP usort(): Array was modified by the user comparison function at /var/www/owncloud/lib/private/User/Manager.php#255 2016-09-18T14:22:36+00:00
