Problem owncloud with mobile login
I have a problem signing in to my owncloud on my phone. The login and password you enter do not work although they are correct. On the computer there is no problem with logging in, it is only on the phone. Please help
Please either provide more information about your setup following the template or delete the template.
Very few people can help you if you just write “I have an error” or “ownCloud doesn’t work”.
That’s why there is template.
