Hello everyone, I installed owncloud (10.3.2) on a raspberry 4 with a rai1 on 2 hdd …
(the Hdd are mounted in / mnt / cloud) I then restored the data of the previous configuration by giving the commands:
sudo systemctl stop apache2
rsync -avz /var/www/owncloud/data /mnt/
ln -s /mnt/data /var/www/owncloud/data
sudo systemctl start apache2
Blockquote
and then given:
Blockquote
chown -R www-data:www-data /
Blockquote
the data has been transferred but I cannot preview it and if I download something I receive the error: "File not found
The specified document was not found on the server.
You can click here to return to ownCloud."
If instead I try to load any data I get the error: Error assembling parts, status code 403
While you might think this is a good idea, I would guess that the data throughput on an RPi would be abysmal in this configuration. (Though I might be wrong as I don’t have a new RPi)
Don’t ever run this command this will destroy your Linux installation.
Judging from what you’re writing here I would guess that the problem is somewhere in your Linux or Apache configuration. And as it is also looking like you’re moving your data directory, you’ll have to make sure you follow the guides perfectly. Check your logs there will be error messages.
With a raspberry 4 (also reading various guides) I think it can afford a raid1 (it will become a raid1 + 0), I’ll place the log file:
Blockquote
{“reqId”:“O4NBRb7wGbp5rIJ2mPrN”,“level”:3,“time”:“2020-01-07T08:44:12+00:00”,“remoteAddr”:“192.168.1.103”,“user”:“Nemo”,“app”:“PHP”,“method”:“GET”,“url”:“/owncloud/remote.php/dav/files/Nemo/IMG_8533.JPG?c=5e9b52a64f2a52fb14027f52b0d1a276&x=64&y=64&forceIcon=0&preview=1”,“message”:“fopen(/mnt/data/Nemo/thumbnails/11100/64-64.png): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#298”}
{“reqId”:“pIbbonYZ6sRuVWhFuiEU”,“level”:3,“time”:“2020-01-07T08:44:12+00:00”,“remoteAddr”:“192.168.1.103”,“user”:“Nemo”,“app”:“PHP”,“method”:“GET”,“url”:“/owncloud/remote.php/dav/files/Nemo/IMG_9145.JPG?c=8cffa458290f2c98fa9af35e755480ef&x=64&y=64&forceIcon=0&preview=1”,“message”:“fopen(/mnt/data/Nemo/thumbnails/11101/64-64.png): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#298”}
{“reqId”:“ogHxsFWDFen29O0E4QYb”,“level”:3,“time”:“2020-01-07T08:48:11+00:00”,“remoteAddr”:“192.168.1.103”,“user”:“Nemo”,“app”:“no app in context”,“method”:“GET”,“url”:“/owncloud/ocs/v2.php/apps/notifications/api/v1/notifications?format=json”,“message”:“User backend OC\User\Database is returning home: /mnt/cloud/data/Nemo for user: Nemo which differs from existing value: /mnt/data/Nemo”}
{“reqId”:“SicjFX8IWQ5pkdEb7p5I”,“level”:3,“time”:“2020-01-07T09:42:36+00:00”,“remoteAddr”:“192.168.1.103”,“user”:“–”,“app”:“no app in context”,“method”:“POST”,“url”:“/owncloud/index.php/login?redirect_url=%252Fowncloud%252Findex.php%252Fapps%252Ffiles%252F%253Fdir%253D%252F”,“message”:“User backend OC\User\Database is returning home: /mnt/cloud/data/Nemo for user: Nemo which differs from existing value: /mnt/data/Nemo”}
{“reqId”:“8aB8oFJgnnCBg10BTwWo”,“level”:3,“time”:“2020-01-07T09:42:38+00:00”,“remoteAddr”:“192.168.1.103”,“user”:“Nemo”,“app”:“PHP”,“method”:“GET”,“url”:“/owncloud/remote.php/dav/files/Nemo/IMG_4807.JPG?c=116f9235532514f45dee1dbb334824a8&x=64&y=64&forceIcon=0&preview=1”,“message”:“fopen(/mnt/data/Nemo/thumbnails/11098/64-64.png): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#298”}
/mnt/data were the old coordinates (when I mounted a single HDD) now I have created 2 folders in /mnt (“nas” and “cloud”), where I then mounted the 3 HDDs, in “nas” runs SAMBA and on “cloud” (where I mounted the HDD in raid1) I have moved the data of owncloud … on the config.php file I entered the new path /mnt/cloud/data … I can’t understand where the error is
To move the given directory from /var/www/owncloud to /mnt/cloud I use this command, to restore the backup from (loading the data from the desktop on a HD) I use instead: rsync -Aax (path of the HDD)
in the config.php file I set the right path “mnt / nas / data” same for the other commands but, I still don’t see the previews and receive the error message when I try to download something
I tried to restore the cloud as it was before the installation of the RAID (therefore only one HD mounted in / mnt without any folder) I keep encountering the same problem … at this point I think it is a database error … Ideas?
