There was a problem sending the email. Check your settings. (Error: Address in mailbox given [info @] does not comply with RFC 2822, 3.6.2.)
Many thank
Many thank
Can you try this fix?
You need to download this, extract it in
/var/www/owncloud/lib/private/Mail
Change the permissions and you should be good to go.
Hi @dmitry
Could you please reshare that code fix please? The link has expired on your server.
Thanks a bunch!
This fix should be in the 10.0.10. Could you update?
I could find the patch the PR.
Hi dmitry.
Well I just installed a new fresh instance of owncloud and it was not working/included.
The bug was still there.
Here is the PR with the fix.
Thank you so much!
Have a wonderful day @dmitry
You too. Let me know how this worked out.
It worked great!
Thank you!
This fix will be in the next release. I asked the responsible engineer. I thought the fix made it in the 10.0.10 release but I was mistaken. Sorry
