Problem - The logout link is different
  1. Connect to the owncloud platform
  2. Disconnect session from the logout link
  3. The disconnect display the error : Deny access - CSRF check failed
When I click on the logout link, the session should be destroy and redirect to the authentification page
URL src : ‘https://myndnsentry/index.php/’
When I click on my logout link,
Sometimes i have this error “Deny access - CSRF check failed” sometimes nothing and the authentification page is dsiplay.
In the both case the session is not destroy
After to have click on logout, If I write the url (‘https://mydnsentry’) i’am always connected
If I check the logout URL, this one should be (‘https://mydnsentry/index.php/login?redirect_url=%252Findex.php%252Flogout%253Frequesttoken%253DImcKCi5GH1E4HGgoHSMKPgEXGRI%25252BVSMjMEQdeRNKNQU%25253D%25253AwSsDD1JbVFPpSqLO3sXfF4Noi2s%25252BIrQKCN5eyy3xbjs%25253D’)
but in place I have
‘https://10.XXX:XXX.XXX/index.php/login?redirect_url=%252Findex.php%252Flogout%253Frequesttoken%253DImcKCi5GH1E4HGgoHSMKPgEXGRI%25252BVSMjMEQdeRNKNQU%25253D%25253AwSsDD1JbVFPpSqLO3sXfF4Noi2s%25252BIrQKCN5eyy3xbjs%25253D’
If i replace the IP adress by the dns name then the session is destroyed
On my plateform, the logout link are different than other links on the plateform. All links have the dns name in their URL
sample : (‘https://myndnsentry/index…’)
But the logout link is the alone have the server local IP instead the dns name and i don’t know why ?
sample :(‘https://10.xxx.xxx.xxx/index…’)
Operating system: Ubuntu 16.04.1 LTS
Web server: Apache/2.4.18 (Ubuntu)
Database: mysql Ver 15.1 Distrib 10.0.28-MariaDB, for debian-linux-gnu (x86_64) using readline 5.2
PHP version: PHP 7.0.8-0ubuntu0.16.04.3
ownCloud version : 9.1.1
Integrity status for oC9+
Configuration file (/var/www/owncloud/config/config.php)
<?php
$CONFIG = array (
  'updatechecker' => false,
  'instanceid' => 'Confidential',
  'passwordsalt' => 'Confidential',
  'secret' => 'Confidential',
  'trusted_domains' =>
  array (
    0 => '10.XXX.XXX.XXX',
    1 => 'mydnsentry',
    2 => '62.XXX.XXX.XXX',
  'datadirectory' => '/ocdata',
  'overwrite.cli.url' => 'https://10.XXX.XXX.XXX/owncloud',
  'dbtype' => 'mysql',
  'version' => '9.1.1.3',
  'dbname' => 'owncloud',
  'dbhost' => 'localhost',
  'dbtableprefix' => 'oc_',
  'dbuser' => 'Confidential',
  'dbpassword' => 'Confidential',
  'logtimezone' => 'Europe/Berlin',
  'installed' => true,
  'mail_smtpmode' => 'smtp',
  'mail_from_address' => 'Confidential',
  'mail_domain' => 'Confidential',
  'mail_smtphost' => 'Confidential',
  'mail_smtpport' => 'Confidential',
Do you have any idea how could i change the logout URL?
You probably need to fiddle around with one of the override config options listed here:
Had the same issue today with combo owncloud docker image and nginx proxy server and solution is to editi config.php located in /var/lib/docker/volumes/owncloud-docker-server_files/_data/config and insert this value ‘overwritehost’ => ‘DNS_name_of_your_OwnCloudWeb’,
