Good morning,
this morning, logging in to my own I encountered this error:
“Cannot write into “config” directory! This can usually be fixed by giving the webserver write access to the config directory”.
I have not made any changes to the config file …
I do not know what to do, does anyone have any idea what to do?
thank you
can you do a ls -al on the config folder in your owncloud directory?
This error occurs if your apache user doesnt have write rights on this directory or if your hard disk is mounted read only.
When I connect to the pages I get the message:
instead giving the command:
chown -R www-data:www-data /var/www/owncloud/config
I get this:“illegal instruction”
