I am trying to update owncloud from version 8.2.10 to 8.2.11. I am using the update-plug-in of owncloud. The back up works, but then I get the error message:
“/www/htdocs/…/…/html/owncloud/data/updater_backup/8.2.11.zip extraction error”
And my provider (all-inkl.com) support says that there is the message:
“pcfg_openfile: unable to check htaccess file, ensure it is readable”
In addition, the support says that the access permissions of </www/htdocs/…/…/html/owncloud/data> seem to be the problem. chmod of is set to 0777.
Any help appreciated!
Addendum:
Error mesage in the owncloud administration area:
Error PHP Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set 'always_populate_raw_post_data' to '-1' in php.ini and use the php://input stream instead. at Unknown#0
Changing chmod of < …owncloud/data> did not solve the problem.
I have downloaded the owncloud-8.2.11.zip from http://ftp.icm.edu.pl/packages/owncloud/ and copied this zip-file into the <…/ownloud/data/updater_backup> directory. Then the update process worked. Owncloud is accessible now without any problem (as far as I see). But how to avoid this effort in the future? Version 9 of owncloud is waiting for installation!
