Hello guys,
i have a problem to connection on my app owncloud.
On my desktop app i have error " broken connection" http://prntscr.com/j3thy7 and on my android app have error "wrong credentials".
The access on browser work fine.
In owncloud.log i see this error:
{"reqId":"f9f6d08f-50b3-4cee-b557-81a859f333b8","level":0,"time":"2018-04-11T13:21:53+00:00","remoteAddr":"xxxxxxxxx","user":"--","app":"webdav","method":"PROPFIND","url":"\/remote.php\/webdav\/","message":"Exception: {\"Message\":\"HTTP\\/1.1 401 No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured\",\"Exception\":\"Sabre\\DAV\\Exception\\NotAuthenticated\",\"Code\":0,\"Trace\":\"#0 [internal function]: Sabre\\DAV\\Auth\\Plugin->beforeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#1 \\/home\\/bertina\\/public_html\\/cloud\\/lib\\/composer\\/sabre\\/event\\/lib\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#2 \\/home\\/bertina\\/public_html\\/cloud\\/lib\\/composer\\/sabre\\/dav\\/lib\\/DAV\\/Server.php(466): Sabre\\Event\\EventEmitter->emit('beforeMethod', Array)\n#3 \\/home\\/bertina\\/public_html\\/cloud\\/lib\\/composer\\/sabre\\/dav\\/lib\\/DAV\\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#4 \\/home\\/bertina\\/public_html\\/cloud\\/apps\\/dav\\/appinfo\\/v1\\/webdav.php(63): Sabre\\DAV\\Server->exec()\n#5 \\/home\\/bertina\\/public_html\\/cloud\\/remote.php(165): require_once('\\/home\\/bertina\\/p...')\n#6 {main}\",\"File\":\"\\/home\\/bertina\\/public_html\\/cloud\\/lib\\/composer\\/sabre\\/dav\\/lib\\/DAV\\/Auth\\/Plugin.php\",\"Line\":168,\"User\":false}"}
i can't understand how solve.
Someone can help me?
