- I run the following command and cron still does not work
crontab -u www-data -e
- / usr / bin / php -f /path/to/your/owncloud/cron.php
- I try to do it manually but it does not work either
sudo -u www-data php -f /var/www/owncloud/cron.php
“PHP Warning: require_once(): open_basedir restriction in effect. File(/var/www/owncloud/lib/base.php) is not within the allowed path(s): (/dev/urandom) in /var/www/owncloud/cron.php on line 36
PHP Warning: require_once(/var/www/owncloud/lib/base.php): failed to open stream: Operation not permitted in /var/www/owncloud/cron.php on line 36
PHP Fatal error: require_once(): Failed opening required ‘/var/www/owncloud/lib/base.php’ (include_path=’.:/usr/share/pear’) in /var/www/owncloud/cron.php on line 36”
- Executing this command I also get the same error
su -s /bin/bash -c ‘/usr/bin/php -f /var/www/owncloud/cron.php’ www-data
I was expecting cron to work
it still does not work cron
Operating system: Debian GNU/Linux 9
Web server: Apache2
Database: MYSQL
PHP version: 0.7
ownCloud version: 10.0.8
Updated from an older ownCloud or fresh install: NO
Where did you install ownCloud from: The server terminal debian
https://gist.github.com/asir214/1edc41e5e2b36c744528de543d8fefae
<?php
$CONFIG = array (
'updatechecker' => false,
'instanceid' => 'oc4knmolaxdj',
'passwordsalt' => '****************',
'secret' => '*****************',
'trusted_domains' =>
array (
0 => '192.168.55.215',
'datadirectory' => '/var/www/owncloud/data',
'overwrite.cli.url' => 'http://192.168.55.215/owncloud',
'dbtype' => 'mysql',
'version' => '10.0.8.5',
'dbname' => 'owncloud',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'dbuser' => 'oc_sistemas2',
'dbpassword' => '***********************',
'logtimezone' => 'UTC',
'installed' => true,
'maintenance' => false,
'memcache.local' => '\\OC\\Memcache\\Redis',
'redis' =>
array (
'host' => 'localhost',
'port' => 6379,
'ldapIgnoreNamingRules' => false,
'debug' => false,
'loglevel' => 0,
'enable_previews' => false,
'logtimezone' => 'Europe/Madrid',
PHP Warning: require_once(): open_basedir restriction in effect. File(/var/www/owncloud/console.php) is not within the allowed path(s): (/dev/urandom) in /var/www/owncloud/occ on line 11
PHP Warning: require_once(/var/www/owncloud/console.php): failed to open stream: Operation not permitted in /var/www/owncloud/occ on line 11
PHP Fatal error: require_once(): Failed opening required '/var/www/owncloud/console.php' (include_path='.:/usr/share/pear') in /var/www/owncloud/occ on line 11
Are you using encryption: no
{"reqId":"XfhVJLOXLm7DAwRDgkKw","level":2,"time":"2018-06-07T17:15:03+02:00","remoteAddr":"192.168.50.180","user":"--","app":"core","method":"POST","url":"\/index.php\/login?user=maider","message":"Login failed: 'maider' (Remote IP: '192.168.50.180')"}
{"reqId":"ze7G7OyqkPnsxNgEge22","level":2,"time":"2018-06-07T17:15:03+02:00","remoteAddr":"192.168.50.180","user":"--","app":"user_ldap","method":"GET","url":"\/index.php\/login?user=maider","message":"Configuration Error (prefix ): No LDAP Login Filter given!"}
{"reqId":"ze7G7OyqkPnsxNgEge22","level":2,"time":"2018-06-07T17:15:03+02:00","remoteAddr":"192.168.50.180","user":"--","app":"user_ldap","method":"GET","url":"\/index.php\/login?user=maider","message":"Configuration Error (prefix ): login filter does not contain %uid place holder."}
{"reqId":"ze7G7OyqkPnsxNgEge22","level":2,"time":"2018-06-07T17:15:03+02:00","remoteAddr":"192.168.50.180","user":"--","app":"user_ldap","method":"GET","url":"\/index.php\/login?user=maider","message":"Configuration Error (prefix s01): No LDAP Host given!"}
{"reqId":"ze7G7OyqkPnsxNgEge22","level":2,"time":"2018-06-07T17:15:03+02:00","remoteAddr":"192.168.50.180","user":"--","app":"user_ldap","method":"GET","url":"\/index.php\/login?user=maider","message":"Configuration Error (prefix s01): No LDAP Login Filter given!"}
{"reqId":"ze7G7OyqkPnsxNgEge22","level":2,"time":"2018-06-07T17:15:03+02:00","remoteAddr":"192.168.50.180","user":"--","app":"user_ldap","method":"GET","url":"\/index.php\/login?user=maider","message":"Configuration Error (prefix s01): login filter does not contain %uid place holder."}
{"reqId":"MqCmTzzt5SCLOURRggFG","level":2,"time":"2018-06-07T17:15:03+02:00","remoteAddr":"192.168.50.180","user":"--","app":"user_ldap","method":"GET","url":"\/index.php\/core\/js\/oc.js?v=f21fc98a37aaed336e9efdbd9ad0ee75","message":"Configuration Error (prefix ): No LDAP Login Filter given!"}
{"reqId":"MqCmTzzt5SCLOURRggFG","level":2,"time":"2018-06-07T17:15:03+02:00","remoteAddr":"192.168.50.180","user":"--","app":"user_ldap","method":"GET","url":"\/index.php\/core\/js\/oc.js?v=f21fc98a37aaed336e9efdbd9ad0ee75","message":"Configuration Error (prefix ): login filter does not contain %uid place holder."}
{"reqId":"MqCmTzzt5SCLOURRggFG","level":2,"time":"2018-06-07T17:15:03+02:00","remoteAddr":"192.168.50.180","user":"--","app":"user_ldap","method":"GET","url":"\/index.php\/core\/js\/oc.js?v=f21fc98a37aaed336e9efdbd9ad0ee75","message":"Configuration Error (prefix s01): No LDAP Host given!"}
{"reqId":"MqCmTzzt5SCLOURRggFG","level":2,"time":"2018-06-07T17:15:03+02:00","remoteAddr":"192.168.50.180","user":"--","app":"user_ldap","method":"GET","url":"\/index.php\/core\/js\/oc.js?v=f21fc98a37aaed336e9efdbd9ad0ee75","message":"Configuration Error (prefix s01): No LDAP Login Filter given!"}
{"reqId":"MqCmTzzt5SCLOURRggFG","level":2,"time":"2018-06-07T17:15:03+02:00","remoteAddr":"192.168.50.180","user":"--","app":"user_ldap","method":"GET","url":"\/index.php\/core\/js\/oc.js?v=f21fc98a37aaed336e9efdbd9ad0ee75","message":"Configuration Error (prefix s01): login filter does not contain %uid place holder."}
{"reqId":"JJ8tGg0Z4PKPjYj1yZ1B","level":2,"time":"2018-06-08T17:53:45+02:00","remoteAddr":"192.168.50.141","user":"--","app":"core","method":"POST","url":"\/index.php\/login","message":"Login failed: 'daniel' (Remote IP: '192.168.50.141')"}
{"reqId":"oU5AqYY9JfPgGMPm93QN","level":3,"time":"2018-06-08T17:53:50+02:00","remoteAddr":"192.168.50.141","user":"--","app":"core","method":"POST","url":"\/index.php\/lostpassword\/email","message":"Could not send reset email because User does not exist. User: daniel"}
{"reqId":"zPbKx2vSE3r9AAI0cKCJ","level":1,"time":"2018-06-11T09:21:31+02:00","remoteAddr":"192.168.50.141","user":"sistemas","app":"no app in context","method":"POST","url":"\/index.php\/settings\/users\/users","message":"Creating new account with UID daniel and backend OC\\User\\Database"}
{"reqId":"zPbKx2vSE3r9AAI0cKCJ","level":3,"time":"2018-06-11T09:21:31+02:00","remoteAddr":"192.168.50.141","user":"sistemas","app":"no app in context","method":"POST","url":"\/index.php\/settings\/users\/users","message":"User backend OC\\User\\Database is returning home: \/var\/www\/owncloud\/data\/daniel for user: daniel which differs from existing value: "}
{"reqId":"zPbKx2vSE3r9AAI0cKCJ","level":0,"time":"2018-06-11T09:21:31+02:00","remoteAddr":"192.168.50.141","user":"sistemas","app":"OC\\User\\SyncService","method":"POST","url":"\/index.php\/settings\/users\/users","message":"Setting home for <daniel> to <\/var\/www\/owncloud\/data\/daniel>"}
{"reqId":"zPbKx2vSE3r9AAI0cKCJ","level":0,"time":"2018-06-11T09:21:31+02:00","remoteAddr":"192.168.50.141","user":"sistemas","app":"OC\\User\\SyncService","method":"POST","url":"\/index.php\/settings\/users\/users","message":"Setting displayName for <daniel> to <daniel>"}
