When I restore a file version (feature available when I click on the file using Web Page Owncloud)
The Owncloud client show a message every next synchronisation.
Message:
This sync would reset the files to an erlier time in the sync folder ‘ownCloud’. This might be because a backup was restored on the server. Continuing the sync as normal will cause all your files to be overwritten by an older file in an earlier state. Do you want to keep your local most recent files as conflict files?
Even if I click “Normal Synchronisation” or “Keep Local Files as Conflict” the message is showed again. -Every sync time
The environment that I’m reproducing the problem
We have this problem on this version
Owncloud Server 9.0 / 9.0.2 and 9.0.4
Server: Linux Ubuntu or CentOS 7 64 bits
Client version: Version 2.2.2 (build 3472) on Mac. BUT the same problem when using Windows PC
11:42:14|194|untitled folder 2|INST_NEW|Up|1469101333||68||4||201|0|0|||INST_NONE|
#=#=#=# Syncrun started until (0 msec)
12:25:13|217|Planilha.xlsx|INST_SYNC|Up|1469103912||22791||4||204|22066|1469050449|a6e04b414892d183b889ae184122e40e|00000090ocsoyurvoemy|INST_NONE|
12:30:10|219|Planilha.xlsx|INST_RENAME|Up|1469103912|a776a05fa2e6fc95a8cefb1534d06372|22791|00000090ocsoyurvoemy|4||201|0|0|||INST_NONE|
12:30:44|362|Test1.xlsx|INST_SYNC|Up|1469104243||23243||4||204|22791|1469103912|a776a05fa2e6fc95a8cefb1534d06372|00000090ocsoyurvoemy|INST_NONE|
12:31:33|210|Test1.xlsx|INST_SYNC|Up|1469104292||24025||4||204|23243|1469104243|1e0193730553035692ff480826ca91a5|00000090ocsoyurvoemy|INST_NONE|
12:33:36|164|Test1.xlsx|INST_SYNC|Down|1469104243|21b03af1bb4d9b259f8af9fcabeb302a|23243|00000090ocsoyurvoemy|4||0|24025|1469104292|||INST_NONE|
12:34:25|221|untitled folder 2|INST_REMOVE|Up|1469101335|5790b5170d107|0|00006481ocsoyurvoemy|4||204|0|0|||INST_NONE|
12:34:39|209|untitled folder|INST_REMOVE|Up|1469064515|57902543d907b|0|00000105ocsoyurvoemy|4||204|0|0|||INST_NONE|
12:35:14|261|Test1.xlsx|INST_SYNC|Up|1469104513||24027||4||204|23243|1469104243|21b03af1bb4d9b259f8af9fcabeb302a|00000090ocsoyurvoemy|INST_NONE|
12:36:31|194|untitled folder|INST_NEW|Up|1469104589||68||4||201|0|0|||INST_NONE|
12:37:02|208|Test1.xlsx|INST_SYNC|Up|1469104620||24453||4||204|24027|1469104513|bb034ef6045bac40364c281ebe948815|00000090ocsoyurvoemy|INST_NONE|
12:38:15|183|Test1.xlsx|INST_SYNC|Down|1469104513|fce09b3724f7c4e4ccdce0e6fe3002ac|24027|00000090ocsoyurvoemy|4||0|24453|1469104620|||INST_NONE|
12:39:28|208|untitled folder|INST_REMOVE|Up|1469104591|5790c1cf6259a|0|00006500ocsoyurvoemy|4||204|0|0|||INST_NONE|
12:42:18|230|teste-srv|INST_REMOVE|Up|1469064422|579024e64f39d|0|00000104ocsoyurvoemy|4||204|0|0|||INST_NONE|
12:42:32|383|Logs|INST_NEW|Up|1469104946||68||4||201|0|0|||INST_NONE|
