I've got this problem since i've stopped using an entire server for owncloud. At first, I installed an entire VM just for ownCloud and recently i've migrated it to an other VM with webmin/virtualmin.
Had the problem with my old installation on virtualmin too, today I decided to update owncloud but the errors are still there. So the problem probably come from a configuration with virtualmin.
1. Installing ownCloud 9.1.4 in a virtualmin virtualserver, file upload with FTP as virtualserver owner
2. Got the integrity problem, lots of extra_files
All files should be ok, or almost
-Got a lot of extra_files under /icon folder
-Got 2 invalid hash files ('core/fonts/LICENSE.txt' and 'core/vendor/jsTimezoneDetect/jstz.js'
-2 more invalid hash at files_external and files_texteditor
Here is the full file -> https://cloud.anywen.ch/index.php/s/hh7rKzoObR0pwlQ
Operating system: CentOS 7
Web server: virtualmin with apache
PHP version: 5.4.16
Updated from an older ownCloud or fresh install: Tried both
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): /data is on a a NFS drive
{"reqId":"WJpEOC1HOjspD8ET4F7bEQAAAAE","remoteAddr":"192.168.1.5","app":"core","message":"starting upgrade from 9.1.0.15 to 9.1.4.2","level":0,"time":"2017-02-07T22:03:36+00:00","method":"GET","url":"\/core\/ajax\/update.php?requesttoken=FAk3DD4gel16VzkgehZ3PFcmGnpEfTEdLwQZJho7DQs%3D%3AQnvTZBLj1oRm2z%2Fu6dVNw4xTd1hI1NjFXwKCictz7Cc%3D","user":"--"}
{"reqId":"WJpLpbmrJFqITRnJO5MugAAAAAc","remoteAddr":"192.168.1.5","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 423 \\\"Photos\\\/2016.09.24 - 50 ans Yves\\\/MVI_5395.MOV\\\" is locked\",\"Exception\":\"OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Exception\\\\FileLocked\",\"Code\":0,\"Trace\":\"#0 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(490): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->convertToSabreException(Object(OCP\\\\Lock\\\\LockedException))\\n#1 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(103): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->createFileChunked(Resource id #387)\\n#2 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(136): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #387)\\n#3 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1036): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile('MVI_5395.MOV-ch...', Resource id #387)\\n#4 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(523): Sabre\\\\DAV\\\\Server->createFile('Photos\\\/2016.09....', Resource id #387, NULL)\\n#5 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#7 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#8 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#9 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(57): Sabre\\\\DAV\\\\Server->exec()\\n#10 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/remote.php(164): require_once('\\\/home\\\/anywen\\\/do...')\\n#11 {main}\",\"File\":\"\\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":546,\"User\":\"Anywen\"}","level":4,"time":"2017-02-07T22:35:18+00:00","method":"PUT","url":"\/remote.php\/webdav\/Photos\/2016.09.24%20-%2050%20ans%20Yves\/MVI_5395.MOV-chunking-3421489191-198-69","user":"Anywen"}
{"reqId":"WJpL@VU7pDBHLpfbfFcG9wAAAAA","remoteAddr":"192.168.1.5","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 423 \\\"Photos\\\/2016.09.24 - 50 ans Yves\\\/MVI_5395.MOV\\\" is locked\",\"Exception\":\"OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Exception\\\\FileLocked\",\"Code\":0,\"Trace\":\"#0 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(490): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->convertToSabreException(Object(OCP\\\\Lock\\\\LockedException))\\n#1 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(103): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->createFileChunked(Resource id #387)\\n#2 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(136): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #387)\\n#3 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1036): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile('MVI_5395.MOV-ch...', Resource id #387)\\n#4 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(523): Sabre\\\\DAV\\\\Server->createFile('Photos\\\/2016.09....', Resource id #387, NULL)\\n#5 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#7 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#8 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#9 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(57): Sabre\\\\DAV\\\\Server->exec()\\n#10 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/remote.php(164): require_once('\\\/home\\\/anywen\\\/do...')\\n#11 {main}\",\"File\":\"\\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":546,\"User\":\"Anywen\"}","level":4,"time":"2017-02-07T22:36:42+00:00","method":"PUT","url":"\/remote.php\/webdav\/Photos\/2016.09.24%20-%2050%20ans%20Yves\/MVI_5395.MOV-chunking-3421489191-198-70","user":"Anywen"}
{"reqId":"WJpL@bmrJFqITRnJO5MugQAAAAc","remoteAddr":"192.168.1.5","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 423 \\\"Photos\\\/2016.09.24 - 50 ans Yves\\\/MVI_5395.MOV\\\" is locked\",\"Exception\":\"OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Exception\\\\FileLocked\",\"Code\":0,\"Trace\":\"#0 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(490): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->convertToSabreException(Object(OCP\\\\Lock\\\\LockedException))\\n#1 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(103): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->createFileChunked(Resource id #387)\\n#2 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(136): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #387)\\n#3 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1036): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile('MVI_5395.MOV-ch...', Resource id #387)\\n#4 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(523): Sabre\\\\DAV\\\\Server->createFile('Photos\\\/2016.09....', Resource id #387, NULL)\\n#5 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#7 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#8 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#9 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(57): Sabre\\\\DAV\\\\Server->exec()\\n#10 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/remote.php(164): require_once('\\\/home\\\/anywen\\\/do...')\\n#11 {main}\",\"File\":\"\\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":546,\"User\":\"Anywen\"}","level":4,"time":"2017-02-07T22:36:42+00:00","method":"PUT","url":"\/remote.php\/webdav\/Photos\/2016.09.24%20-%2050%20ans%20Yves\/MVI_5395.MOV-chunking-3421489191-198-69","user":"Anywen"}
{"reqId":"WJpL@afkO7UZvT8qApQNVAAAAAY","remoteAddr":"192.168.1.5","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 423 \\\"Photos\\\/2016.09.24 - 50 ans Yves\\\/MVI_5395.MOV\\\" is locked\",\"Exception\":\"OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Exception\\\\FileLocked\",\"Code\":0,\"Trace\":\"#0 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(490): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->convertToSabreException(Object(OCP\\\\Lock\\\\LockedException))\\n#1 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(103): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->createFileChunked(Resource id #387)\\n#2 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(136): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #387)\\n#3 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1036): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile('MVI_5395.MOV-ch...', Resource id #387)\\n#4 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(523): Sabre\\\\DAV\\\\Server->createFile('Photos\\\/2016.09....', Resource id #387, NULL)\\n#5 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#7 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#8 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#9 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(57): Sabre\\\\DAV\\\\Server->exec()\\n#10 \\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/remote.php(164): require_once('\\\/home\\\/anywen\\\/do...')\\n#11 {main}\",\"File\":\"\\\/home\\\/anywen\\\/domains\\\/cloud.anywen.ch\\\/public_html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":546,\"User\":\"Anywen\"}","level":4,"time":"2017-02-07T22:36:43+00:00","method":"PUT","url":"\/remote.php\/webdav\/Photos\/2016.09.24%20-%2050%20ans%20Yves\/MVI_5395.MOV-chunking-3421489191-198-71","user":"Anywen"}
Integrity status for oC9+
If someone have an hint, I'm taking it.
Thank you and have a nice day.
