I Finished installing Owncloud server on my machine, very impressive by the way. I was able to fix all the error messages except the code integrity check for “lib/composer/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php” it all comes from ubuntu’s repository and re-install doesn’t fix the problem. Wondering why the hash check is not valid and what I can do to fix it. I can’t find another intl.php outside of ubuntu’s repo and frankly, only want to use the repo. Can this be ignored or is it a real risk? Thank you in advance for your time, information and help.
1.install ubuntu 20.04 (Linux)
2.install and setup owncloud’s dependencies from Ubuntu’s repository (Apache Mysql Php)
3.install owncloud
4. login as admin
The hash check for “lib/composer/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php” should match
The hash check for “lib/composer/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php” doesn’t match.
Integrity error file:
https://gist.githubusercontent.com/IrkenGir/87fb93bae9970ab98e2c40541a076590/raw/cab4afc024e5bfc8937abea52f78357ed89c5e4a/Failed_integrity.txt
contents of config/config.php will not be shared here.
config_report.json is 8900 lines, I uploaded it on github, it has all the server and software info.
https://gist.githubusercontent.com/IrkenGir/814a2505d0910e4e043f1f8264c89d69/raw/ac59b460c2dd5fc0ff37a526e876df4a6ea21c63/Config_report_20210120.json
