Hello everyone,
I’ve got the problem during the login in, when I type a correct login and the password I get the info:
“You took too long to login, please try again now”
What’s that, what is the problem?
I use ovh servers, with no sql.
browser google chrome.
Let me know, what I should to do.
Regards,
Lukas
Hi Lukas,
Could you tell me the errors in the Log files? ownCloud and Apache.
If you don’t has SQL, what are you using?
Could you provide a config report?
i think there are a few threads available in this forums which discusses this message and where i think that you can find various possible solutions.
