When OC is loaded on my computer the ability to right-click on a file in Windows File Explorer causes FE to crash. I have narrowed this problem to be caused by OC by removing all applications from the Boot sequence and then reloading them one at a time and rebooting the computer. IT was not until OC was loaded that this problem re-occured with FE. This is not a server/cloud-related issue it only happens on the desktop.
ownCloud version:
Client version:
OS language:
Installation path of client:
logs.
Client logfile: Output of
owncloud --logwindow
orowncloud --logfile log.txt
(On Windows usingcmd.exe
, you might need to firstcd
into the ownCloud directory)
(See also Redirect Notice ) -
Web server error log:
