Problem with setting up cron
I am a new user of ownCloud and right now I’m trying to set up the Cron on the system. The configuration seems to be OK, but I keep getting this message from Cron system:
PHP Parse error: syntax error, unexpected ‘.’ in /home/login/domains/dharmaebooks.com/private_html/owncloud/apps/dav/lib/CardDAV/CardDavBackend.php on line 498
Log says: 3,“time”:“2018-07-14T16:25:01+00:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"–",“url”:"–",“message”:“syntax error, unexpected ‘.’ at /home/login/domains/dharmaebooks.com/private_html/owncloud/apps/dav/lib/CardDAV/CardDavBackend.php#498”}
Operating system: MacOs
PHP version: 7.0
ownCloud version: (see ownCloud admin page) 10.0.8.5
Where did you install ownCloud from: Host
**Signing status (ownCloud 9.0 and above):**10.0.8
maybe the PHP version used by cron is newer / older then the one used by your webserver for ownCloud?
Thank you. That is quite possible. For now I have set up webcrone. Unfortunatelly adding php70 doesnt help…
