Problem with sharing files
I am unable to share any file. When share option is clicked then side panel is showing on the right side of page and under Sharing tab loading circle is spinning forever.
1.Just installed version 9.1 (previously version 9.0.2) from tarball
2. I was trying to share one of my file but the loading circle is going to spin forever
Showing sharing options and finally allowing to share file/files
Not showing sharing options
Operating system: Lubuntu 16.04.01
Web server: nginx 1.10
Database: postgres 9.5
PHP version: 7.0
Updated from an older ownCloud or fresh install: updated from 9.02 but on prev version (clean install) same beahvior
Integrity status for oC9+
Can you explain how you managed to update step-by-step?
probably you’ve missed one or two steps.
here is what i usually do when i upgrade an ownCloud-instance:
cd /var/www/html/owncloud sudo -u www-data php occ maintenance:singleuser --on mv /var/www/html/owncloud/data /var/www/oc_data cp /var/www/html/owncloud/config/config.php /var/www/oc_config.php rm -rf /var/www/html/owncloud cd /var/www/html && wget https://download.owncloud.org/community/owncloud-9.0.4.tar.bz2 tar xjvf owncloud-9.0.4.tar.bz2 chown -R www-data:www-data /var/www/html/owncloud cd /var/www/html/owncloud sudo -u www-data php occ upgrade sudo -u www-data php occ encryption:migrate sudo -u www-data php occ files:scan --all sudo -u www-data php occ maintenance:singleuser --off
and if you’re going to run the security-script, which is highly recommended btw, then dont forget to run that as well(not listed here). afterwards set your .htacces, .user.ini, my.cnf, php.ini to the values which covers your needs.
i hope i dint forget anything as well :smile:
