I have a client installed on my computer. Everything worked so far, but the application started reporting a problem with file access rights. As a result, I cannot sync to the account from the computer resources.
Finally, I reinstalled the Client (in the newest and in the older version: 2.7). When I am configuring the account, I cannot complete the procedure because I get a message that “I do not have the right to write to the directory”. System explorer performs the write correctly.
I think the most important point is that the directory that is being written to is a mapped drive. On the file server side (Synology), I have all write permissions and Windows explorer behaves properly.
Previously, this configuration worked. The same problem occurs on another computer (Win 7 / Win 10) On Synology, allegedly no one made changes.
If logs or other information are needed, I will send it, thank you in advance.
