I suspect that there is a problem with the offline function in the iOS app in both direction.
The data is displayed quickly and can also be viewed. Only when I turn on the offline function, the synch no longer works properly. That is, after 2-3 files the iPhone crashes and from then on nothing happens. The display to the right of the file rotates, but does not happen. This state can last several hours before some data is synchronized again. If you want to load e.g. 8 pictures (each about 3MB) from the iPhone to the server, only about 3-4 pictures go very fast and from then on again the behavior described before. The remaining pictures are uploaded only after days or not at all.
I suspect that there is a problem with the offline function in the iOS app.
Web server: Synology NAS ds124 with actual DSM
**Database:**Apache HTTP Server 2.4
**PHP version:**7.4
**ownCloud version:**10.13.1
Client
**iOS version:**17.0.3
**ownCloud app version:**12.0.3 build 282
**Device model:**SE 2022
Sorry, since it is a corporate device, I am not allowed to distribute log files. I hope you can still help.
