Problem with trusted_domains
  1. install OC serveur on ubuntu 16.04
  2. installa and configure OC basicaly (first user, first pwd)
  3. launch OC over the web browser and login
I can’t loggin into my owncloud installation in a browser other than the server web browser. when a try from a other PC on a local host, i have this message
this is the configuration of my config.php
$CONFIG = array (
  'instanceid' => 'oc46m1pmfamr',
  'passwordsalt' => 'zt3rbPjPM00vRakUGqVZTB8Gokzztp',
  'secret' => 'xuvN/GCakDmKotOafxwHgkMdvqtOIrkk9Uh+J5nzWL7+zTKF',
  'trusted_domains' =>
  array (
    0 => '192.168.0.100:80',
    1 => '154.72.161.189',
    2 => '192.168.0.100:3000',
    3 => '192.168.0.108',
    4 => '192.168.0.106',
    5 => '192.168.0.100',
    6 => '192.168.0.118',
    7 => 'server.dev',
  'datadirectory' => '/var/www/html/owncloud/data',
  'overwrite.cli.url' => '192.168.0.100/owncloud',
  'dbtype' => 'mysql',
  'version' => '9.1.2.5',
  'dbname' => 'owncloud',
  'dbhost' => 'localhost',
  'dbtableprefix' => 'oc_',
  'dbuser' => 'root',
  'dbpassword' => 'madiaroot',
  'logtimezone' => 'UTC',
  'installed' => true,
  'loglevel' => 0,
but when i run owncloud with php as server (inside owncloud folder)
php -S 0:3000
the installation work fine
Operating system: Ubuntu Linux 16.04
Web server: Server version: Apache/2.4.18 (Ubuntu), Server built: 2016-07-18T18:32:02
Database: MySQL 5.7
PHP version: PHP 7.0.15-0ubuntu0.16.10.4 (cli) ( NTS )
ownCloud version : ownCloud 9.1.2 (stable)
Updated from an older ownCloud or fresh install: fresh Install
{"reqId":"JW1qigFeuS3r0HlWFVsM","remoteAddr":"127.0.0.1","app":"PHP","message":"mkdir(): Permission denied at \/var\/$
{"reqId":"JBPV7BoRHHsw8CMTeSgy","remoteAddr":"192.168.0.105","app":"PHP","message":"chmod(): Operation not permitted $
{"reqId":"CD\/zJ+rVKWFSFIH53xqz","remoteAddr":"192.168.0.105","app":"PHP","message":"chmod(): Operation not permitted$
{"reqId":"0YAIeZfWkq6ySR3KG0Lw","remoteAddr":"192.168.0.105","app":"PHP","message":"chmod(): Operation not permitted $
{"reqId":"l4r494drhhse346vYmwA","remoteAddr":"192.168.0.105","app":"PHP","message":"chmod(): Operation not permitted $
{"reqId":"NJv\/oPnuzguBjed9mURD","remoteAddr":"192.168.0.105","app":"PHP","message":"chmod(): Operation not permitted$
{"reqId":"JW1qigFeuS3r0HlWFVsM","remoteAddr":"127.0.0.1","app":"PHP","message":"mkdir(): Permission denied at \/var\/www\/html\/owncloud\/lib\/private\/Setup.php#288","level":3,"time":"2016-11-25T16:43:39+00:00","method":"POST","url":"\/owncloud\/index.php","user":"--"}
{"reqId":"JBPV7BoRHHsw8CMTeSgy","remoteAddr":"192.168.0.105","app":"PHP","message":"chmod(): Operation not permitted at \/var\/www\/html\/owncloud\/lib\/private\/Config.php#232","level":3,"time":"2017-01-23T14:52:00+00:00","method":"POST","url":"\/owncloud\/index.php","user":"--"}
{"reqId":"CD\/zJ+rVKWFSFIH53xqz","remoteAddr":"192.168.0.105","app":"PHP","message":"chmod(): Operation not permitted at \/var\/www\/html\/owncloud\/lib\/private\/Config.php#232","level":3,"time":"2017-01-23T14:53:13+00:00","method":"POST","url":"\/owncloud\/index.php","user":"--"}
{"reqId":"CD\/zJ+rVKWFSFIH53xqz","remoteAddr":"192.168.0.105","app":"PHP","message":"chmod(): Operation not permitted at \/var\/www\/html\/owncloud\/lib\/private\/Config.php#232","level":3,"time":"2017-01-23T14:53:35+00:00","method":"POST","url":"\/owncloud\/index.php","user":"--"}
{"reqId":"CD\/zJ+rVKWFSFIH53xqz","remoteAddr":"192.168.0.105","app":"PHP","message":"chmod(): Operation not permitted at \/var\/www\/html\/owncloud\/lib\/private\/Config.php#232","level":3,"time":"2017-01-23T14:53:36+00:00","method":"POST","url":"\/owncloud\/index.php","user":"yannick"}
{"reqId":"0YAIeZfWkq6ySR3KG0Lw","remoteAddr":"192.168.0.105","app":"PHP","message":"chmod(): Operation not permitted at \/var\/www\/html\/owncloud\/lib\/private\/legacy\/util.php#920","level":3,"time":"2017-01-23T14:53:50+00:00","method":"GET","url":"\/owncloud\/index.php\/apps\/files\/","user":"yannick"}
{"reqId":"l4r494drhhse346vYmwA","remoteAddr":"192.168.0.105","app":"PHP","message":"chmod(): Operation not permitted at \/var\/www\/html\/owncloud\/lib\/private\/legacy\/util.php#920","level":3,"time":"2017-01-23T14:53:50+00:00","method":"GET","url":"\/owncloud\/index.php\/core\/js\/oc.js?v=65d56d2e6ca5c46fa03adc731692e1e5","user":"yannick"}
{"reqId":"NJv\/oPnuzguBjed9mURD","remoteAddr":"192.168.0.105","app":"PHP","message":"chmod(): Operation not permitted at \/var\/www\/html\/owncloud\/lib\/private\/legacy\/util.php#920","level":3,"time":"2017-01-23T14:53:50+00:00","method":"GET","url":"\/owncloud\/cron.php","user":"yannick"}
{"reqId":"9WDCOeWnFWKJ\/hrcT5nl","remoteAddr":"192.168.0.105","app":"PHP","message":"chmod(): Operation not permitted at \/var\/www\/html\/owncloud\/lib\/private\/legacy\/util.php#920","level":3,"time":"2017-01-23T14:54:21+00:00","method":"GET","url":"\/owncloud\/index.php","user":"yannick"}
{"reqId":"xB67Y0bf3hz\/iyYUoqvx","remoteAddr":"192.168.0.105","app":"PHP","message":"chmod(): Operation not permitted at \/var\/www\/html\/owncloud\/lib\/private\/legacy\/util.php#920","level":3,"time":"2017-01-23T14:54:21+00:00","method":"GET","url":"\/owncloud\/index.php\/core\/js\/oc.js?v=65d56d2e6ca5c46fa03adc731692e1e5","user":"yannick"}
{"reqId":"yguJR3CBcgAJ77JIb5GW","remoteAddr":"192.168.0.105","app":"PHP","message":"chmod(): Operation not permitted at \/var\/www\/html\/owncloud\/lib\/private\/legacy\/util.php#920","level":3,"time":"2017-01-23T14:54:21+00:00","method":"GET","url":"\/owncloud\/cron.php","user":"yannick"}
{"reqId":"DwD9PyumCO56eMiuxwt7","remoteAddr":"192.168.0.106","app":"core","message":"Login failed: 'root' (Remote IP: '192.168.0.106')","level":2,"time":"2017-03-15T09:41:25+00:00","method":"POST","url":"\/index.php\/login","user":"--"}
{"reqId":"hEk76XgAS5o8M2ON6DsW","remoteAddr":"192.168.0.106","app":"core","message":"Could not get application: cURL error 28: Operation timed out after 20000 milliseconds with 0 out of 0 bytes received","level":3,"time":"2017-03-15T10:28:43+00:00","method":"POST","url":"\/index.php\/settings\/ajax\/enableapp.php","user":"yannick"}
{"reqId":"rXDmHp8csAegIN+NlJgJ","remoteAddr":"127.0.0.1","app":"core","message":"Login failed: 'root' (Remote IP: '127.0.0.1')","level":2,"time":"2017-03-15T11:29:43+00:00","method":"POST","url":"\/index.php\/login","user":"--"}
{"reqId":"ddR\/aYINlkAHEhZckM5r","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:30:47+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"hrCUOW2ESnjTL0ac1WO\/","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:30:49+00:00","method":"GET","url":"\/","user":"--"}
{"reqId":"XBVyrLF8YhTHAtmsWnFQ","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:30:49+00:00","method":"GET","url":"\/index.php\/core\/js\/oc.js?v=1dd4b3e28d33cbccfb30fd34aefd3f09","user":"--"}
{"reqId":"8HfvYxedpdZIxhmkfhvU","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:30:49+00:00","method":"GET","url":"\/cron.php","user":"--"}
{"reqId":"b1y+UabrCF3AABUrce\/5","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:31:18+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"MoyNOrRvrdu\/a4NMplOM","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:31:43+00:00","method":"GET","url":"\/","user":"--"}
{"reqId":"9LouOBXDdAmCtLXtuW6n","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:31:43+00:00","method":"GET","url":"\/index.php\/core\/js\/oc.js?v=1dd4b3e28d33cbccfb30fd34aefd3f09","user":"--"}
{"reqId":"MgS5nAmvtb\/tboNLPOhm","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:31:43+00:00","method":"GET","url":"\/cron.php","user":"--"}
{"reqId":"M5hQx++FIg633WpMIw78","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:31:50+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"hmMWryHMV9hdvRimWcMJ","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:32:22+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"PoCe8jCLPbF0PoNeofqJ","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:32:54+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"xDBiOeEOHRm5v0Fm7xDC","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:33:26+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"7jQl\/rIYKbK\/P9ZEaTky","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:33:58+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"Qdb1MUpxJPweDKF0qbFL","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:34:30+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"ydGjPLQImYlBDPMv4VHx","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:35:02+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"AGxPwm7pjL\/e5\/Yihu86","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:35:34+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"0Zjoq8SbM1gUen\/VSiEi","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:36:06+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"N87ayLm\/bPfS2EiQPMFX","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:36:38+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"DJV3DyEOfUa8TztKme1X","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:37:10+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"tjHeKZ67Ler7UA9r\/J5U","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:37:42+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"fymsxIiAJG7djW1wTZE6","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:38:14+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"CRESMy4ixwDXaxVvbouz","remoteAddr":"192.168.0.106","app":"core","message":"Trusted domain error. \"192.168.0.106\" tried to access using \"192.168.0.100:3000\" as host.","level":2,"time":"2017-03-16T12:38:46+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"fugCh5FMMKjjLDmTnYPj","remoteAddr":"192.168.0.106","app":"core","message":"Login failed: 'root' (Remote IP: '192.168.0.106')","level":2,"time":"2017-03-16T12:44:49+00:00","method":"POST","url":"\/index.php\/login","user":"--"}
{"reqId":"cAuaS7C2rJVqcuSfUhz6","remoteAddr":"192.168.0.106","app":"core","message":"Login failed: 'madia' (Remote IP: '192.168.0.106')","level":2,"time":"2017-03-16T14:01:57+00:00","method":"POST","url":"\/index.php\/login","user":"--"}
{"reqId":"ZJ3L5Y87SNq\/Xvwcyq9G","remoteAddr":"192.168.0.108","app":"core","message":"Login failed: 'madia' (Remote IP: '192.168.0.108')","level":2,"time":"2017-03-16T14:54:12+00:00","method":"POST","url":"\/index.php\/login","user":"--"}
{"reqId":"w6mmSnToh7wBPTKvtYOd","remoteAddr":"192.168.0.108","app":"core","message":"Login failed: 'madia' (Remote IP: '192.168.0.108')","level":2,"time":"2017-03-16T14:54:16+00:00","method":"POST","url":"\/index.php\/login?user=madia","user":"--"}
{"reqId":"loVxu+E3SNXAmeW6FDOk","remoteAddr":"192.168.0.108","app":"core","message":"Login failed: 'madia' (Remote IP: '192.168.0.108')","level":2,"time":"2017-03-16T14:55:10+00:00","method":"POST","url":"\/index.php\/login?user=madia","user":"--"}
{"reqId":"NREoututZcgncWv48fhz","remoteAddr":"192.168.0.108","app":"core","message":"Login failed: 'root' (Remote IP: '192.168.0.108')","level":2,"time":"2017-03-16T14:55:15+00:00","method":"POST","url":"\/index.php\/login?user=madia","user":"--"}
{"reqId":"DxDrsEHQu6NAQjrpuoTF","remoteAddr":"192.168.0.108","app":"core","message":"Login failed: 'root' (Remote IP: '192.168.0.108')","level":2,"time":"2017-03-16T14:55:21+00:00","method":"POST","url":"\/index.php\/login?user=root","user":"--"}
{"reqId":"8aGaycJGC5vZGI36n8I4","remoteAddr":"192.168.0.108","app":"core","message":"Login failed: 'root' (Remote IP: '192.168.0.108')","level":2,"time":"2017-03-16T14:55:25+00:00","method":"POST","url":"\/index.php\/login?user=root","user":"--"}
{"reqId":"S8f\/Z3qBlDD86Xfg2NGQ","remoteAddr":"192.168.0.108","app":"core","message":"Login failed: 'madia' (Remote IP: '192.168.0.108')","level":2,"time":"2017-03-16T14:55:34+00:00","method":"POST","url":"\/index.php\/login?user=root","user":"--"}
Integrity status for oC9+
Your trusted_domains settings doesn’t look right. Have a look at the documentation at [1].
To sum-up: The trusted_domains setting needs to contain the IP/Domain of your server (the part you’re putting into your browser), not of the clients accessing the server
[1] ownCloud Documentation Overview
Thanks for your answer.
my local server IP adress is 192.168.0.100, but when i put this IP adress, i have the same problem.
okay, this documentation is pretty vague. I’m putting this here for future reference.
The “trusted_domain” is the FQDN of your server. A better example for the documentation would be:
1=> ‘myserver.mydomain.org’,
2=> ‘10.0.1.10’, <- where this is the IP of your server.
