- WebDav
- Cron
Apache2
MySQL
"remoteAddr":"192.168.2.1","user":"admin","app":"webdav","method":"PROPFIND","url":"\/remote.php\/dav\/files\/admin\/","message":"Exception: HTTP\/1.1 503 Doctrine\\DBAL\\Exception\\DriverException: An exception occurred while executing 'SELECT `id`, `uid`, `login_name`, `password`, `name`, `type`, `token`, `last_activity`, `last_check` FROM `oc_authtoken` WHERE `token` = ?' with params [\"5483183323db6539d9ed06b598bf909affaf4a7473066cc4cd61a34e4704fe5120774dfb1748a302fd911a76b1919b8d989d85d68a0bcf71b31a91e5ddc16c64\"]:\n\nSQLSTATE[HY000]: General error: 1712 Index oc_authtoken is corrupted: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\ServiceUnavailable\",\"Message\":\"Doctrine\\\\DBAL\\\\Exception\\\\DriverException: An exception occurred while executing 'SELECT `id`, `uid`, `login_name`, `password`, `name`, `type`, `token`, `last_activity`, `last_check` FROM `oc_authtoken` WHERE `token` = ?' with params [\\\"5483183323db6539d9ed06b598bf909affaf4a7473066cc4cd61a34e4704fe5120774dfb1748a302fd911a76b1919b8d989d85d68a0bcf71b31a91e5ddc16c64\\\"]:\\n\\nSQLSTATE[HY000]: General error: 1712 Index oc_authtoken is corrupted\",\"Code\":0,\"Trace\":\"#0 [internal function]: {closure}(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#1 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Object(Closure), Array)\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(466): Sabre\\\\Event\\\\EventEmitter->emit('beforeMethod', Array)\\n#3 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#4 \\\/var\\\/www\\\/owncloud\\\/remote.php(70): Sabre\\\\DAV\\\\Server->exec()\\n#5 \\\/var\\\/www\\\/owncloud\\\/remote.php(167): handleException(Object(Doctrine\\\\DBAL\\\\Exception\\\\DriverException))\\n#6 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/remote.php\",\"Line\":68}"}
{"reqId":"cdSA3wJC17mRfTttAVwl","level":3,"time":"2018-11-07T16:14:40+01:00","remoteAddr":"192.168.2.1","user":"admin","app":"PHP","method":"GET","url":"\/ocs\/v2.php\/apps\/notifications\/api\/v1\/notifications?format=json","message":"Doctrine\\DBAL\\Exception\\DriverException: An exception occurred while executing 'SELECT `id`, `uid`, `login_name`, `password`, `name`, `type`, `token`, `last_activity`, `last_check` FROM `oc_authtoken` WHERE `token` = ?' with params [\"45bb1fd7366df8cb6f3995b668ddfdaeb807722dd27d4f082a4499f10f12325544fffdb2b0be1cc3e128d8c5927e5817dfe01b9e6c3161826b96de5411ebe483\"]:\n\nSQLSTATE[HY000]: General error: 1712 Index oc_authtoken is corrupted at \/var\/www\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/AbstractMySQLDriver.php#115"}
Die letzten Zeilen von
Zeige nur Zeilen mit dem Text
