Problems with code integrity check
Hi.
I am running ownCloud on Linux Mint 19 Tara (Cinnamon).
After some trouble, version 10.0.8 was working fine. After upgrading to 10.0.9 I get the following integrity check error:
Operating system: Linux Mint 19 Tara (Cinnamon)
Web server: http://stuffanddollup.servebeer.com/owncloud
Database: mySQL
PHP version: 7.2.7
ownCloud version: (see ownCloud admin page) 10.0.9
Updated from an older ownCloud or fresh install: Update from 10.0.8
Where did you install ownCloud from: Repository
Signing status (ownCloud 9.0 and above): ??
Are you using external storage, if yes which one: local/smb/sftp/… no
Are you using encryption: yes/no no
Browser: Firefox
maybe it could help other users to understand if you describe what troubles you’re facing and which info you’re additional require to solve this issue besides the documentation mentioned in the “the previous linked documentation” text.
Hi.
The ‘troubles’ were related to installing Linux on a computer and struggling to get ownCloud working. Once that was done everything worked ok.
After upgrading ownCloud to 10.0.9 I get this file integrity error.
I want it to go away and am looking for help to make it so.
did you had a look at the previous mentioned Documentation? It looks to me that this provides exact steps what to do when facing an “EXTRA_FILE” integrity error.
