OK, not so happy now. I did get apache to access the /home/userdir but, I am trying to run owncloud in /home/cloud/public_html. Everything works fine until I setenforce 1 again. As instructed via Owncloud server setup instructions here is what I have done:
1. setenforce 0
semanage fcontext -a -t httpd_sys_rw_content_t '/home/cloud/public_html/data(/.*)?'
semanage fcontext -a -t httpd_sys_rw_content_t '/home/cloud/public_html/config(/.*)?'
semanage fcontext -a -t httpd_sys_rw_content_t '/home/cloud/public_html/apps(/.*)?'
semanage fcontext -a -t httpd_sys_rw_content_t '/home/cloud/public_html/.htaccess'
semanage fcontext -a -t httpd_sys_rw_content_t '/home/cloud/public_html/.user.ini'
restorecon -Rv '/var/www/html/owncloud/'
However, once I setenforce back to 1 I get a white page. Running this
ls -Z /home/cloud/public_html/config (or any other directory)[/code] I get the following:[code]-rw-r-----. apache apache system_u:object_r:httpd_sys_rw_content_t:s0 config.php
Log entries: [Fri Dec 28 01:24:34.649662 2018] [:error] [pid 28652] [client 10.1.4.50:62148] PHP Fatal error: Uncaught exception 'Doctrine\\DBAL\\DBALException' with message 'Failed to connect to the database: An exception occurred while executing 'PRAGMA journal_mode = WAL':\n\nSQLSTATE[HY000]: General error: 14 unable to open database file' in /home/backups/public_html/lib/private/DB/Connection.php:58\nStack trace:\n#0 /home/backups/public_html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(973): OC\\DB\\Connection->connect()\n#1 /home/backups/public_html/lib/private/DB/Connection.php(209): Doctrine\\DBAL\\Connection->executeUpdate('PRAGMA read_unc...', Array, Array)\n#2 /home/backups/public_html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(621): OC\\DB\\Connection->executeUpdate('PRAGMA read_unc...')\n#3 /home/backups/public_html/lib/private/DB/Connection.php(141): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#4 /home/backups/public_html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrine\\DBAL\\Driver\\PDOSqlite\\Driver), Object(Doctrine\\D in /home/backups/public_html/lib/private/DB/Connection.php on line 58
Any suggestions
