Product placement of Nextcloud
Just stumbled over [1] where ownCloud was replaced by NextCloud (and from a NC employee) in the description.
There is no single sign, neither at [2] nor at [3] that now only NextCloud is mentioned and not ownCloud. It seems the NextCloud product placement is working (yeah, its all about the Community…)
[1] DavDroid now mentions Nextcloud instead of ownCloud, makes sense to follow that … (!1880) · Merge requests · F-Droid / Data · GitLab
[2] https://davdroid.bitfire.at/
[3] https://play.google.com/store/apps/details?id=at.bitfire.davdroid
Thanks for raising the awareness. It probably needs someone from the OC community or OC team to create a pull request to put owncloud back on the list.
On fdroid owncloud is still named - see Files · master · F-Droid / Data · GitLab
I also still see owncloud named/listed on [2] and [3] - I see no issue so far.
THX
@DeepDiver1975 This was fixed / changed back recently:
