I have Owncloud (10.11.0) with very large directory structure. I found this article Syncing Faster: ownCloud Server 10.9 released - ownCloud
When I try to enable/disable it with ‘dav.propfind.depth_infinity’ => true, and check what is different when try to add server to Windows Owncloud client (last version 2.11.1), nothing is changed - windows client is checking for every single folder when propfind is enabled or disabled.
When i disable it and try
curl -XPROPFIND https://USER:PASS@SERVER/remote.php/webdav -H "Depth:infinity" -k
i get
<?xml version="1.0" encoding="utf-8"?>
<d:error xmlns:d="DAV:" xmlns:s="http://sabredav.org/ns">
<s:exception>Sabre\DAV\Exception\PreconditionFailed</s:exception>
<s:message>Depth infinity not supported</s:message>
</d:error>
When i enable it, i will get response with directory tree and more info. Is Windows client using this feature?
Thank you, Margi.
