- install owncloud 10
- upload any document
- create a public link
- try to access the public link from any computer outside the network the owncloud server
should be able to access the public link
says “cannot access from untrusted domain”
ubuntu 18.04
apache
mariadb
10
fresh
apt-get
not signed i guess
