Hello, everybody,
after updating Owncloud to 10.3.0 via the updater there is a problem with folders shared in Owncloud.
There are folders shared with the members of a group. The folders are accessible to all. But if a member of the group who is not the creator of the folder wants to share files or the folder via a public link, he gets the message:
“An error occurred while sending the mail. No email could be sent to the following recipients: Mail address”
Only the creator of the shared folder can share it in this way. This is the case for all users, as well as for newly created and shared folders. So it is a general problem.
With all own folders / files this problem does not exist, there the mails are sent.
I am grateful for every hint!
Translated with www.DeepL.com/Translator
- share a shared folder via public link
Email should be fired
An error occurred while sending the mail. No email could be sent to the following recipients: Mail address"
~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.3 LTS
Release: 18.04
Codename: bionic
~$ apache2 -v
Server version: Apache/2.4.29 (Ubuntu)
Server built: 2019-09-16T12:58:48
MariaDB [(none)]> select @@version;
| 10.3.18-MariaDB-1:10.3.18+maria~bionic-log |
~$ php -v
PHP 7.2.24-0ubuntu0.18.04.1 (cli) (built: Oct 28 2019 12:07:07) ( NTS )
Zend Engine v3.2.0,
with Zend OPcache v7.2.24-0ubuntu0.18.04.1
10.3.0.4
Update from 10.0.2 over updater
owncloud zip packet
clean
“system”: {
“instanceid”: “oc7pslajdbmf”,
“theme”: “goebber”,
“trusted_domains”: [
“transfers.goebber.de”,
“transferstest.goebber.de”,
“localhost”,
“192.168.2.11”
“datadirectory”: “/var/www/owncloud/data”,
“overwrite.cli.url”: “https://transfers.goebber.de”,
“dbtype”: “mysql”,
“version”: “10.3.0.4”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“logtimezone”: “UTC”,
“apps_paths”: [
“path”: “/var/www/owncloud/apps”,
“url”: “/apps”,
“writable”: false
“path”: “/var/www/owncloud/apps-external”,
“url”: “/apps-external”,
“writable”: true
“installed”: true,
“memcache.local”: “\OC\Memcache\APCu”,
“memcache.locking”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “localhost”,
“port”: 6379,
“timeout”: 0,
“password”: “REMOVED SENSITIVE VALUE”
“mail_smtpmode”: “smtp”,
“mail_smtpport”: “25”,
“preview_libreoffice_path”: “/usr/bin/libreoffice”,
“enable_certificate_management”: true,
“allow_user_to_change_display_name”: “true”,
“loglevel”: 2,
“maintenance”: false
Enabled:
- activity: 2.5.0
- calendar: 1.6.3
- comments: 0.3.0
- configreport: 0.2.0
- contacts: 1.5.5
- dav: 0.5.0
- encryption: 1.4.0
- federatedfilesharing: 0.5.0
- federation: 0.1.0
- files: 1.5.2
- files_antivirus: 0.15.1
- files_external: 0.7.1
- files_mediaviewer: 1.0.0
- files_pdfviewer: 0.11.0
- files_sharing: 0.12.0
- files_texteditor: 2.3.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.10.1
- firstrunwizard: 1.2.0
- gallery: 16.1.1
- market: 0.5.0
- notifications: 0.5.0
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.4.0
- updatenotification: 0.2.1
- user_ldap: 0.13.0
Disabled: - external
- user_external
no
yes
LDAP
| Configuration | s01 |
| hasMemberOfFilterSupport | 1 |
| hasPagedResultSupport | |
| homeFolderNamingRule | |
| lastJpegPhotoLookup | 0 |
| ldapAgentName | CN=Service,OU=xxx,OU=Organisation,DC=xxx,DC=xxx |
| ldapAgentPassword | *** |
| ldapAttributesForGroupSearch | |
| ldapAttributesForUserSearch | |
| ldapBackupHost | xxx.xxx.xxx.xxx |
| ldapBackupPort | 389 |
| ldapBase | DC=xxx,DC=xxx |
| ldapBaseGroups | DC=xxx,DC=xxx |
| ldapBaseUsers | DC=xxx,DC=xxx |
| ldapCacheTTL | 600 |
| ldapConfigurationActive | 1 |
| ldapDynamicGroupMemberURL | |
| ldapEmailAttribute | mail |
| ldapExperiencedAdmin | 0 |
| ldapExpertUUIDGroupAttr | |
| ldapExpertUUIDUserAttr | objectguid |
| ldapExpertUsernameAttr | sAMAccountName |
| ldapGroupDisplayName | cn |
| ldapGroupFilter | |
| ldapGroupFilterGroups | |
| ldapGroupFilterMode | 0 |
| ldapGroupFilterObjectclass | |
| ldapGroupMemberAssocAttr | uniqueMember |
| ldapHost | xxx.xxx.xxx.xxx |
| ldapIgnoreNamingRules | |
| ldapLoginFilter | (&(&(|(objectclass=person))(|(|(memberof=CN=Owncloud,OU=Arbeitsgruppen,OU=Gruppen,OU=Organisation,DC=xxx,DC=xxx)(primaryGroupID=9863))))(|(samaccountname=%uid)(|(mailPrimaryAddress=%uid)(mail=%uid))(|(displayName=%uid)(mail=%uid)))) |
| ldapLoginFilterAttributes | displayName;mail |
| ldapLoginFilterEmail | 1 |
| ldapLoginFilterMode | 0 |
| ldapLoginFilterUsername | 1 |
| ldapNestedGroups | 0 |
| ldapOverrideMainServer | |
| ldapPagingSize | 500 |
| ldapPort | 389 |
| ldapQuotaAttribute | |
| ldapQuotaDefault | |
| ldapTLS | 0 |
| ldapUserDisplayName | displayName |
| ldapUserDisplayName2 | |
| ldapUserFilter | (&(|(objectclass=person))(|(|(memberof=CN=Owncloud,OU=Arbeitsgruppen,OU=Gruppen,OU=Organisation,DC=xxx,DC=xxx)(primaryGroupID=9863)))) |
| ldapUserFilterGroups | Owncloud |
| ldapUserFilterMode | 0 |
| ldapUserFilterObjectclass | person |
| ldapUserName | samaccountname |
| ldapUuidGroupAttribute | auto |
| ldapUuidUserAttribute | auto |
| turnOffCertCheck | 0 |
| useMemberOfToDetectMembership | 1 |
all
all
\/core\/templates\/layout.user.php#130"}
[Wed Nov 06 00:09:04.965553 2019] [ssl:warn] [pid 1324] AH01909: owncl01.xxx.xxx:443:0 server certificate does NOT include an ID which matches the server name
[Wed Nov 06 00:09:05.091619 2019] [ssl:warn] [pid 1324] AH01909: owncl01.xxx.xxx:443:0 server certificate does NOT include an ID which matches the server name
[Wed Nov 06 00:09:05.092028 2019] [ssl:warn] [pid 1324] AH01909: owncl01.xxx.xxx:443:0 server certificate does NOT include an ID which matches the server name
[Wed Nov 06 00:09:05.092399 2019] [ssl:warn] [pid 1324] AH01909: owncl01.xxx.xxx:443:0 server certificate does NOT include an ID which matches the server name
[Wed Nov 06 00:09:05.092562 2019] [mpm_prefork:notice] [pid 1324] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.1 configured – resuming normal operations
[Wed Nov 06 00:09:05.092570 2019] [core:notice] [pid 1324] AH00094: Command line: ‘/usr/sbin/apache2’
[Wed Nov 06 13:41:15.650010 2019] [authz_core:error] [pid 94690] [client xxx.xxx.xxx.xxx:32599] AH01630: client denied by server configuration: /var/www/owncloud/data/htaccesstest.txt
[Wed Nov 06 13:59:21.517434 2019] [authz_core:error] [pid 94679] [client xxx.xxx.xxx.xxx:43692] AH01630: client denied by server configuration: /var/www/owncloud/data/htaccesstest.txt
[Wed Nov 06 15:02:53.462156 2019] [authz_core:error] [pid 94679] [client xxx.xxx.xxx.xxx:25429] AH01630: client denied by server configuration: /var/www/owncloud/data/htaccesstest.txt
[Wed Nov 06 15:15:04.735398 2019] [authz_core:error] [pid 95388] [client xxx.xxx.xxx.xxx:31417] AH01630: client denied by server configuration: /var/www/owncloud/data/htaccesstest.txt
the log is too big, here are excerpts of a user it doesn’t work for
{“reqId”:“XbhQtE6pCzCqHTCh2EZeQQAAAAU”,“level”:3,“time”:“2019-10-29T14:46:12+00:00”,“remoteAddr”:“192.168.2.1”,“user”:“xxx”,“app”:“PHP”,“method”:“GET”,“url”:"/index.php/apps/files/",“message”:“include(layout.noscript.warning.php): failed to open stream: No such file or directory at /var/www/owncloud/themes/xxx/core/templates/layout.user.php#35”}
{“reqId”:“XbhQtE6pCzCqHTCh2EZeQQAAAAU”,“level”:3,“time”:“2019-10-29T14:46:12+00:00”,“remoteAddr”:“xxx.xxx.xxx.xxx”,“user”:“xxx”,“app”:“PHP”,“method”:“GET”,“url”:"/index.php/apps/files/",“message”:“include(): Failed opening ‘layout.noscript.warning.php’ for inclusion (include_path=’/var/www/owncloud/apps:/var/www/owncloud/apps-external’) at /var/www/owncloud/themes/xxx/core/templates/layout.user.php#35”}
{“reqId”:“XbhQtE6pCzCqHTCh2EZeQQAAAAU”,“level”:3,“time”:“2019-10-29T14:46:12+00:00”,“remoteAddr”:“xxx.xxx.xxx.xxx”,“user”:“xxx”,“app”:“no app in context”,“method”:“GET”,“url”:"/index.php/apps/files/",“message”:“Exception: {“Exception”:“Symfony\\Component\\Routing\\Exception\\RouteNotFoundException”,“Message”:“Unable to generate a URL for the named route \“settings.AppSettings.viewApps\” as such route does not exist.”,“Code”:0,“Trace”:”#0 \/var\/www\/owncloud\/lib\/private\/Route\/Router.php(382): Symfony\\Component\\Routing\\Generator\\UrlGenerator->generate(‘settings.AppSet…’, Array, 1)\n#1 \/var\/www\/owncloud\/lib\/private\/Route\/CachingRouter.php(60): OC\\Route\\Router->generate(‘settings.AppSet…’, Array, false)\n#2 \/var\/www\/owncloud\/lib\/private\/URLGenerator.php(86): OC\\Route\\CachingRouter->generate(‘settings.AppSet…’, Array)\n#3 \/var\/www\/owncloud\/themes\/goebber\/core\/templates\/layout.user.php(129): OC\\URLGenerator->linkToRoute(‘settings.AppSet…’)\n#4 \/var\/www\/owncloud\/lib\/private\/Template\/Base.php(219): include(’\/var\/www\/ownclo…’)\n#5 \/var\/www\/owncloud\/lib\/private\/Template\/Base.php(194): OC\\Template\\Base->load(’\/var\/www\/ownclo…’, NULL)\n#6 \/var\/www\/owncloud\/lib\/private\/legacy\/template.php(236): OC\\Template\\Base->fetchPage(NULL)\n#7 \/var\/www\/owncloud\/lib\/private\/legacy\/template.php(258): OC_Template->fetchPage()\n#8 \/var\/www\/owncloud\/lib\/public\/AppFramework\/Http\/TemplateResponse.php(149): OC_Template->fetchPage()\n#9 \/var\/www\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(108): OCP\\AppFramework\\Http\\TemplateResponse->render()\n#10 \/var\/www\/owncloud\/lib\/private\/AppFramework\/App.php(100): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OCA\\Files\\Controller\\ViewController), ‘index’)\n#11 \/var\/www\/owncloud\/lib\/private\/AppFramework\/Routing\/RouteActionHandler.php(47): OC\\AppFramework\\App::main(‘ViewController’, ‘index’, Object(OC\\AppFramework\\DependencyInjection\\DIContainer), Array)\n#12 \/var\/www\/owncloud\/lib\/private\/Route\/Router.php(342): OC\\AppFramework\\Routing\\RouteActionHandler->__invoke(Array)\n#13 \/var\/www\/owncloud\/lib\/base.php(920): OC\\Route\\Router->match(’\/apps\/files\/’)\n#14 \/var\/www\/owncloud\/index.php(54): OC::handleRequest()\n#15 {main}",“File”:"\/var\/www\/owncloud\/lib\/composer\/symfony\/routing\/Generator\/UrlGenerator.php",“Line”:113}"}
{“reqId”:“XbhQtE6pCzCqHTCh2EZeQQAAAAU”,“level”:3,“time”:“2019-10-29T14:46:12+00:00”,“remoteAddr”:“xxx.xxx.xxx.xxx”,“user”:“xxx”,“app”:“PHP”,“method”:“GET”,“url”:"/index.php/apps/files/",“message”:“Undefined index: appsmanagement_active at /var/www/owncloud/themes/xxx
/core/templates/layout.user.php#130”}
