How can I see my qnap (TS-853 Pro) in owncloud?
I execute the owncloud x app in qnap. But in the opening owncloud session I can’t find a way to access to my qnap. I’ve already read this ownCloud on QNAP :: ownCloud Documentation but it didn’t work.
Thank you
which app do you use?
This one: https://www.qnap.com/de-de/app_center/con_show.php?op=showone&internalName=owncloudv10&version=10.0.10.1&qts=5.0.0&seq=81&os=qts
Or this one https://github.com/owncloud/qnap-packaging/releases/tag/v10.8.0.0 ?
I would recommend you to create a network share on the QNAP and add it as external storage Samba File Server Configuration (SMB/CIFS) :: ownCloud Documentation
Thank you wkloucek!
I’m using the version 10.0.10.1.
I will try to create an external storage on qnap.
Do you think that webDAV can be a good alternative to samba?
