I get this error, after following the ‘Windows development build’ of this manual (https://doc.owncloud.org/desktop/2.2/building.html):
Could not find a package configuration file provided by “Qt5WebKit” with
** any of the following names:**
** Qt5WebKitConfig.cmake**
** qt5webkit-config.cmake**
** Add the installation prefix of “Qt5WebKit” to CMAKE_PREFIX_PATH or set**
** “Qt5WebKit_DIR” to a directory containing one of the above files. If**
** “Qt5WebKit” provides a separate development package or SDK, be sure it has**
** been installed.**
Call Stack (most recent call first):
** src/CMakeLists.txt:8 (include)**
CMake Error at cmake/modules/QtVersionAbstraction.cmake:34 (message):
** Qt5WebKit required for Shibboleth. Use -DNO_SHIBBOLETH=1 to disable it.**
– Configuring incomplete, errors occurred!
See also “C:/git_clones/qtkeychain/CMakeFiles/CMakeOutput.log”.
See also “C:/git_clones/qtkeychain/CMakeFiles/CMakeError.log”.
