good evening, I have a big problem. I want to give 50 Gb or even 2 Tb to one of my users but when I set the quota. I go to the application and the quota is 39.1 GB and if I go back to the admin application it is 60Gb or more. how to solve this problem?
Not sure what happened with the template, but you need to fill the following form as much as possible.
