Hi, since yesterday my rainloop settings is missing from the personal page. On my personal page there was a section for rainloop where I could add login details to automatically log in, but this section is no longer available. I can still see the rainloop settings on the admin page.
I tried disabling/re-enable rainloop I downloaded a copy from the app store and replaced the rainloop folder on my server
Server configuration Operating system: Linux Web server: Shared hositng MySQL Version: 10.0.27-MariaDB PHP version: 5.6.25 ownCloud version :9.1.0
Integrity status for oC9+ No errors have been found.
as this doesn't happen out of the blue a first starting point would be to gather / research whats changed in your environment from yesterday to the day before.
I installed owncloud yesterday morning. I installed rainloop, email, contracts & calendar. Rainloop worked fine. I uploaded some contacts and that was all. I can reinstall owncloud altogether, but I don't want to have to reinstall it every second day.
Well if stating that I (as admin) did not make any changes except upload contacts is not sufficient and there is no log to check if any background activity was running then I assume I will not be able to find a solution here.
If you check the "Automatically login with ownCloud user credentials" checkbox in the Admin page, it will automatically hide the "RainLoop Webmail" settings section in the "Personal" settings page.
I reinstalled ownCloud and did not check the "Automatically login with ownCloud user credentials" checkbox the second time. Thus it isn't a problem anymore.
