Hello:
I currently have a Raspberry Pi 3 running an Owncloud server using Apache and MySQL. Problem is that the Owncloud server crashes regularly. I cannot access the server via SSH (using Putty). Only way to gain access is to pull the power and plug it back in. I can then access everything (Shell In a Box, Webmin except when I try using the web interface to access my Owncloud i get the error:
********* is currently unable to handle this request.
HTTP ERROR 500
- After re imaging SD card, use Owncloud
Log in to Owncloud, should work as it does after re imaging sd card.
HTTP ERROR 500
Operating system: Debian 8
Web server: Apache
PHP version: 5.6
ownCloud version: 9.1, fresh install
ownCloud log: Empty file
Cannot login as Admin user as I cannot access Owncloud at all.
Contents of MySQL error.log file:
InnoDB: Page number (if stored to page already) 2936,
InnoDB: space id (if created with >= MySQL-4.1.1 and stored already) 0
InnoDB: Page may be an index page where index id is 62
InnoDB: Database page corruption on disk or a failed
InnoDB: file read of page 2936.
InnoDB: You may have to recover from a backup.
InnoDB: It is also possible that your operating
InnoDB: system has corrupted its own file cache
InnoDB: and rebooting your computer removes the
InnoDB: error.
InnoDB: If the corrupt page is an index page
InnoDB: you can also try to fix the corruption
InnoDB: by dumping, dropping, and reimporting
InnoDB: the corrupt table. You can use CHECK
InnoDB: TABLE to scan your table for corruption.
InnoDB: See also http://dev.mysql.com/doc/refman/5.5/en/forcing-innodb-recovery.html
InnoDB: about forcing recovery.
InnoDB: Ending processing because of a corrupt database page.
160904 22:16:47 InnoDB: Assertion failure in thread 1783977040 in file buf0buf.c line 3623
InnoDB: We intentionally generate a memory trap.
InnoDB: Submit a detailed bug report to http://bugs.mysql.com.
InnoDB: If you get repeated assertion failures or crashes, even
InnoDB: immediately after the mysqld startup, there may be
InnoDB: corruption in the InnoDB tablespace. Please refer to
InnoDB: http://dev.mysql.com/doc/refman/5.5/en/forcing-innodb-recovery.html
05:16:47 UTC - mysqld got signal 6 ;
This could be because you hit a bug. It is also possible that this binary
or one of the libraries it was linked against is corrupt, improperly built,
or misconfigured. This error can also be caused by malfunctioning hardware.
We will try our best to scrape up some info that will hopefully help
diagnose the problem, but since we have already crashed,
something is definitely wrong and this may fail.
key_buffer_size=16777216
read_buffer_size=131072
max_used_connections=0
max_threads=151
thread_count=0
connection_count=0
It is possible that mysqld could use up to
key_buffer_size + (read_buffer_size + sort_buffer_size)*max_threads = 346093 K bytes of memory
Hope that's ok; if not, decrease some variables in the equation.
Thread pointer: 0x0
Attempting backtrace. You can use the following information to find out
where mysqld died. If you see no messages after this, something went
terribly wrong...
stack_bottom = 0 thread_stack 0x30000
The manual page at http://dev.mysql.com/doc/mysql/en/crashing.html contains
information that should help you find out what is causing the crash.
160904 22:16:47 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
Contents of my Apache2 error.log:
[Sun Sep 04 22:15:05.209113 2016] [:error] [pid 1305] [client 10.0.0.1:52208] PHP Fatal error: Uncaught exception 'Doctrine\\DBAL\\DBALException' with message 'Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)' in /var/www/owncloud/lib/private/DB/Connection.php:58\nStack trace:\n#0 /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(621): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/owncloud/lib/private/DB/Connection.php(141): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Co in /var/www/owncloud/lib/private/DB/Connection.php on line 58
[Sun Sep 04 22:15:05.213097 2016] [:error] [pid 1305] [client 10.0.0.1:52208] PHP Fatal error: Uncaught exception 'Doctrine\\DBAL\\DBALException' with message 'Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)' in /var/www/owncloud/lib/private/DB/Connection.php:58\nStack trace:\n#0 /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(621): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/owncloud/lib/private/DB/Connection.php(141): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Co in /var/www/owncloud/lib/private/DB/Connection.php on line 58
If I reload a backup image onto the SD card, everything goes back to perfect… for a while… until another crash occurs.
Any help would be greatly appreciated as many searched online have come up empty handed… and I’m getting pretty frustrated!
Thanks!!!
