- installed owncloud version 10.4.1
- php -v is running on 7.3.14
- Not able to open up owncloud page. Getting the internal server error as per below
Should be able to go to owncloud page
Page showing this error.
<?php /** * @author Jörn Friedrich Dreyer * @author Lukas Reschke * @author Morris Jobke * @author Philipp Schaffrath * @author RealRancor * @author Robin Appelman * @author Sergio BertolÃn * @author Thomas Müller * @author Vincent Petry * * @copyright Copyright (c) 2018, ownCloud GmbH * @license AGPL-3.0 * * This code is free software: you can redistribute it and/or modify * it under the terms of the GNU Affero General Public License, version 3, * as published by the Free Software Foundation. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU Affero General Public License for more details. * * You should have received a copy of the GNU Affero General Public License, version 3, * along with this program. If not, see * */ // Show warning if a PHP version below 7.1.0 is used, this has to happen here // because base.php will already use 7.1 syntax. if (\version_compare(PHP_VERSION, '7.1.0') === -1) { echo 'This version of ownCloud requires at least PHP 7.1.0'; echo 'You are currently running PHP ' . PHP_VERSION . '. Please update your PHP version.'; return; } // Show warning if PHP 7.4 or later is used as ownCloud is not compatible with PHP 7.4 if (\version_compare(PHP_VERSION, '7.4.0alpha1') !== -1) { echo 'This version of ownCloud is not compatible with PHP 7.4
'; echo 'You are currently running PHP ' . PHP_VERSION . '.'; return; } // running oC on Windows is unsupported since 8.1, this has to happen here because // is seems that the autoloader on Windows fails later and just throws an exception. if (\stripos(PHP_OS, 'WIN') === 0) { echo 'ownCloud Server does not support Microsoft Windows.'; return; } try { require_once __DIR__ . '/lib/base.php'; OC::handleRequest(); } catch (\OC\ServiceUnavailableException $ex) { \OC::$server->getLogger()->logException($ex, ['app' => 'index']); //show the user a detailed error page OC_Response::setStatus(OC_Response::STATUS_SERVICE_UNAVAILABLE); OC_Template::printExceptionErrorPage($ex); } catch (\OC\HintException $ex) { OC_Response::setStatus(OC_Response::STATUS_SERVICE_UNAVAILABLE); OC_Template::printErrorPage($ex->getMessage(), $ex->getHint()); } catch (\OC\User\LoginException $ex) { OC_Response::setStatus(OC_Response::STATUS_FORBIDDEN); OC_Template::printErrorPage($ex->getMessage()); } catch (\OCP\Files\ForbiddenException $ex) { OC_Response::setStatus(OC_Response::STATUS_FORBIDDEN); OC_Template::printErrorPage($ex->getMessage()); } catch (\Throwable $ex) { try { \OC::$server->getLogger()->logException($ex, ['app' => 'index']); //show the user a detailed error page OC_Response::setStatus(OC_Response::STATUS_INTERNAL_SERVER_ERROR); OC_Template::printExceptionErrorPage($ex); } catch (\Throwable $ex2) { // with some env issues, it can happen that the logger couldn't log properly, // so print out the exception directly // NOTE: If we've reached this point, something has gone really wrong because // we couldn't even get the logger, so don't rely on ownCloud here. \header("{$_SERVER['SERVER_PROTOCOL']} 599 Broken"); \OC::crashLog($ex); \OC::crashLog($ex2); } } ### Server configuration **Operating system**: **Web server:** Apache/2.4.38 (Raspbian) **Database:** **PHP version:** PHP 7.3.14-1~deb10u1 (cli) (built: Feb 16 2020 15:07:23) ( NTS ) **ownCloud version:** (see ownCloud admin page) 10.4.1 **Updated from an older ownCloud or fresh install:** i deleted and do a fresh installation. **Where did you install ownCloud from:** command line download 10.4.1.zip wget https://download.owncloud.org/community/owncloud-10.4.1.zip **Signing status (ownCloud 9.0 and above):** ``` Login as admin user into your ownCloud and access http://example.com/index.php/settings/integrity/failed paste the results into https://gist.github.com/ and puth the link here. ``` **The content of config/config.php:** ``` Log in to the web-UI with an administrator account and click on 'admin' -> 'Generate Config Report' -> 'Download ownCloud config report' This report includes the config.php settings, the list of activated apps and other details in a well sanitized form. or If you have access to your command line run e.g.: sudo -u www-data php occ config:list system from within your ownCloud installation folder *ATTENTION:* Do not post your config.php file in public as is. Please use one of the above methods whenever possible. Both, the generated reports from the web-ui and from occ config:list consistently remove sensitive data. You still may want to review the report before sending. If done manually then it is critical for your own privacy to dilligently remove *all* host names, passwords, usernames, salts and other credentials before posting. You should assume that attackers find such information and will use them against your systems. ``` **List of activated apps:** ``` If you have access to your command line run e.g.: sudo -u www-data php occ app:list from within your ownCloud installation folder. ``` **Are you using external storage, if yes which one:** local/smb/sftp/... No **Are you using encryption:** yes/no **Are you using an external user-backend, if yes which one:** LDAP/ActiveDirectory/Webdav/... #### LDAP configuration (delete this part if not used) ``` With access to your command line run e.g.: sudo -u www-data php occ ldap:show-config from within your ownCloud installation folder Without access to your command line download the data/owncloud.db to your local computer or access your SQL server remotely and run the select query: SELECT * FROM `oc_appconfig` WHERE `appid` = 'user_ldap'; Eventually replace sensitive data as the name/IP-address of your LDAP server or groups. ``` ### Client configuration **Browser:** **Operating system:** ### Logs #### Web server error log ``` Insert your webserver log here ``` #### ownCloud log (data/owncloud.log) ``` Insert your ownCloud log here ``` #### Browser log ``` Insert your browser log here, this could for example include: a) The javascript console log b) The network log c) ... ```
