Rebuild index: SQLSTATE[HY000] [2002] - But MySQL up and running
Hi all,
had to move owncloud 8.0 to another server, experienced some trouble regarding acessibility of files for some users, so I tried to rebuild index by:
php console.php files:scan --all
got error:
exception ‘Doctrine\DBAL\DBALException’ with message ‘An exception occured in driver: SQLSTATE[HY000] [2002] php_network_getaddresses: getaddrinfo failed: Name or service not known’ in lib/private/db/connection.php:33
Regarding this point Manual says “If you’re using MySQL please start your database.”
But both MySQL and Owncloud are running. Besides: Since it is a hosted system I cannot restart such services as MySQL, because I only have very limited console access.
php -m says:
mysql
PDO
pdo_mysql
pdo_sqlite
Got slightly different PHP-Versions for CLI and Web:
php -v: PHP 5.6.28-he.0
phpinfo: PHP Version 5.6.31-he.0
(“he” possibly stands for the hoster “Host Europe”)
Might that be the problem?
Any hints?
Kind regards
Thilo
Maybe contact the support of your hoster? The php_network_getaddresses: getaddrinfo failed: Name or service not known doesn’t look right and is probably some problem on your operating system / PHP setup.
The Hoster adviced me to change to PHP7. Did so but error remains. Now CLI still has PHP5.6, web has PHP7 :frowning:
Moved the complete installation to one of my servers with root access, no problem here. So it must be a hoster-related issue.
Will try again…
Host Europe said their SSH-Proxy denies Access to the MySQL-Server, which is remote and not localhost, when connecting from command line.
So now I need a script that establishes MySQL-Connection and then runs php occ…
Will try myself and search the Internet, any advice is greatly appreciated. :blush:
